Old 12-09-2003, 08:17 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Cold air = bad???
I was reading the reviews on 2gnt and then i read this one... http://www.2gnt.com/nuke/modules.php...wcontent&id=85
It was saying that cold air is actually bad for your engine, you need some warm air, the cold air will dry the gas before it gets burned. Is this really true???
For Sale 98 Eclipse GS, 5 spd
Old 12-09-2003, 09:43 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Cold air = bad???
from what i know cold air is always better for your combustion...
1
Shift_BOOST
97 s14
Old 12-09-2003, 12:20 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Cold air intakes can easily suck up water which is bad for the engine.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 12-09-2003, 01:44 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
it doesnt suck it up that easily, more likly to when there is a really bad rain storm or you are driving through puddles, a lake, or a river but other than that it isnt bad at all, i know when i use to have it i just wouldnt drive crazy in the rain, and i never had a problem!
Old 12-09-2003, 01:59 PM
ashah000's Avatar
I am not talking about the water!!!
Old 12-09-2003, 04:02 PM
EclipseRST's Avatar
Banned
well duckydsp was and thats who i was replying to!!! OBVIOUSLY
and now i will reply to you, colder air is better for the engine! why would companys make intercoolers? and cold air intakes if it wasnt? its been proven a hundred times that your cars performance is better with cooler air, its not like the air is 5 degrees... it is somewhat warm, you engine is gunna perform differnt in the winter anyway so i am talking about summer weather! the temperature of the air on average in the summer depending on where you live will most likly be in the 60-80 degrees, now tell me that that temp is cold!!!
Old 12-09-2003, 07:28 PM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
colder air is more dense and pack in more oxygen making your car burn your fuel more efficiantly, in turn leading to higher hp and overall performance. Now, cold air can be a problem if the air is very cold and your not giving your engin enough fuel. That can cause your car to run too lean, and cause engine failur. only if you have a larger turbo with stock injectors and a large intercooler would you really have to worry about getting too cold of air which very rarley happens. I personaly havnt herd of anybody blowing up motors because of too cold of air but i have read about it a few times.
Old 12-09-2003, 11:25 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: Re: Cold air = bad???
on a side note, i had a shop instructor in high school that said the optimum air intake teperature is 47.8 deg Farenheit. anyone know any more about this???
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 12-10-2003, 07:03 AM
kjewer1 kjewer1 is offline
AF - Advisor
I've never heard of that, and it seems way to accurate (to one decimal place) to be true. But, on the other hand, the stock 2g ECU (and perhaps 1g, never looked into it) WILL pull 1 degree of timing out below 35 degrees, just like it will over 84 degrees. Coincidence? I never really stopped to question why they do that, I'll have to look into it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-10-2003, 07:12 PM
95_GSX's Avatar
well to my understanding that was what temp was found in a lab in which the fuel and air could make the most power. and again that was just what i was told. the instructer knew his shit though. he use to run in a mini tractor pull series. and had been a mechanic all his life. so i trust him in the information he gave. but i guess it will be something to research.
Got AWD?
'08 Buell 1125R
Old 12-10-2003, 07:26 PM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
From what I know intake air can be too cold. Air too cold prevents fuel from properly vaporizing. This is more of a problem for engines using a Carb. Fuel injection I would assume is only effected mildly. Overall the cooler and dryer the better I would say, simply because the turbo is going to heat it all up again. I ran a few weeks ago with my hood off and noticed a slight increase in power. The temp was like 35 degrees something like 30% humidity. Head stayed nice and cool along with the turbo.
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 12-11-2003, 10:17 AM
Kaleco Kaleco is offline
Send a message via AIM to Kaleco
the only theory i heard about cold air...is with the turbo...that cold air with a turbo messes up air : fuel ratio or something like that...that's what i heard is tru about the new Evo...but i dunno if that is tru about the older DSM's is it and is it even tru with the EVO?
Old 12-11-2003, 11:45 AM
AF - Advisor
Only if the ECU is shyte. There is an intake temp sensor in all cars (except those with hot-wire air flowsensors, the sensor itself takes air temp into account by the process by which is measures air) that will compensate so AFR stays correct. No dSM or EVO will have problems with this.
Kevin Jewer
Old 12-13-2003, 03:01 PM
swest_jefe swest_jefe is offline
I dont know if you can get TOO cold, but on a turbo car im sure you want as cool as possible because the pressure increase is going to heat it quite a bit, so I doubt you could get too cold air into the engine.
Old 12-13-2003, 03:14 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
id have to agree with that it does not matter how cold it is that turbo will heat it up nice and warm.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
