Old 12-09-2003, 07:38 AM
TJW002 TJW002 is offline
1996 Grand Am GT will not start/crank.
Car has been running fine. Last night after work, it would not start/crank. Headlights, radio, dashboard lights, sensor lights all work fine. No clicking sound from the starter. Any ideas? Thanks!
Old 12-09-2003, 08:36 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: 1996 Grand Am GT will not start/crank.
When was battery changed?
Old 12-09-2003, 12:13 PM
Re: Re: 1996 Grand Am GT will not start/crank.
New battery in July of 2002.
Old 12-10-2003, 08:05 AM
justin0419 justin0419 is offline
I had an S-10 truck once that had the starter seize up on it. The battery was fine, lights all worked, etc. When I'd try to start it, it wouldn't turn over (no noise from the starter or anything). You may want to pull the starter off and get it bench tested at an auto parts store.
Old 12-10-2003, 01:19 PM
2001CAV 2001CAV is offline
Find Out If It Has Had A Recall Done On It To Install A Starter
Relay.you Can Look Under The Hood And On The Upper Radiator
Support Around The Middle And Look For A Silver Relay Bolted
To The Support.if It Does Not Have It There Is A Good Posiblity
That The Starter Melted The Ignition Switch Causing Your No
Start.the Good Thing About That Is If It Is The Problem Any
Pontiac Dealer Can Preform The Recall Install The Relay And
Ignition Switch For Free.the Recall # Is 02008b.you Can Also
Call A Pontiac Dealer With The Vin # And They Can Tell You If
It Has Been Done.
