Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-09-2003, 03:18 AM
jpo jpo is offline
93 Ranger 4x4 not engaging
My Rangers 4x4 is not engaging when pushing the electronic engage button. I have checked all fuses and looked at the electrical connections on the Transfercase. Except for some grime on the connections all wires look fine. I had just used the 4x4 about 3 weeks ago when it snowed and there was no weird mechanical sounds and everything worked fine. Please any suggestions would be much appreciated.
Old 12-09-2003, 08:09 AM
TheRangerOfDanger TheRangerOfDanger is offline
I don't even know if this is still the case (since yours is newer)--you probably already knew this--- but try going in reverse for a while, and then forward. Usually, you have to go the oppossite direction you engaged 4x4 in to get out of it, so maybe you should just try going in reverse to engage it?? worth a shot
Old 12-09-2003, 09:46 PM
EVH5150 EVH5150 is offline
I had the same problems last winter where the 4WD was engaged bud after a few seconds of engaging I'd hear a grinding noise along with a loss of traction. Turned out the front hubs were shot. That might be the case for you. good luck.
Old 12-10-2003, 10:06 AM
originalmike's Avatar
originalmike originalmike is offline
Send a message via AIM to originalmike Send a message via MSN to originalmike Send a message via Yahoo to originalmike
It could be the electronics in the switch. On my 98 Ford Ranger the same thing happened and I had to replace the chipset.
Old 12-23-2003, 04:42 PM
Katoom Katoom is offline
Fixing the Auto Ford 4X4 - Detailed instructions
http://www.glue.umd.edu/~singletn/exp.html
This is a wicked site that covers most common problems with the Ford Explorer.....a not so distant cousin to the Ford Ranger. I just helped a friend repair automatic hubs.
This site was awesome......nobody will service auto-hubs, they just tell you to replace them with the manual lockers. Even the dealerships do this too.
This site actually shows the root cause (buildup of thick grease) in the hubs that causes them not to operate properly. We tore his hubs down and were able to follow the instructions to make the auto-hubs work like new.
There is also great instructions on the transfer case motor and how to service it instead of replacing it and spending a lot of money.
Enjoy!
Old 12-23-2003, 07:34 PM
Haven't replaced my hubs yet. I'll have to check out this site before I blow my cash on new hubs. Thanks for the info.
Old 12-24-2003, 01:31 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
is the front axlw not engaging or is the transfercase not shifting? If it is not shifting then just get someone to keep on pushing the 4x4 button while you get under your truck and gently tap on the shifter motor casing That usually works 99.99% of the time
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-24-2003, 10:51 AM
You shouldn't have to tap on the transfer case motor! Thats why i posted the link. There are great instructions on how to fix the motors so they function like new.
Old 12-24-2003, 05:53 PM
Hypsi87's Avatar
Re: 93 Ranger 4x4 not engaging
yea but when your ranger is worh about 10 bucks it's kinda hard to put much tiime or monney in to it, tapping on the motor is free and does not take long.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 02-21-2004, 11:09 PM
atccontroller atccontroller is offline
92 ranger auto hubs not working
My 92 Ranger is not engaging. I've pulled off the shift motor.. Cleaned it and it's like new. However, the motor will not run when the switch is pressed. Switch tests fine. The computer has been replaced. The motor, when jumped with 12V will turn both ways but when in 4HI, no lights on the switch lite up. But in 4LO they both work. So I'm thinking that the shift motor is bad.
Also, I have WARN manual's to replace. I pulled the tire and the hub and they are LOADED with grease! Do I read this thread right that there should be NO grease at all in the hub? They turn freely and when turned to lock they "stop"... ??? The spine has lots of grease too!
Should the spine and all that stuff, including the hub be spotless??
I'm replacing the motor since I need to have the electronics working before I start ripping off hubs.
Thanks for any advice/information.
Alan
Old 02-22-2004, 09:07 PM
There is some sort of a "reset" button on the computer....have you tried that? I would. If that doesn't work it almost sounds like part of the feedback circuit isn't working to let the computer know what position the transfer case is in? Have you read the post about the stopper that goes bad inside the motor? If not send me an E-mail at [email protected] and I will send you the link.
Manual hubs don't seem to care if they have grease in them or not. In fact on my 93 Ranger, I pack them full of grease. This is the wrong situation to have for the auto hubs though. If you have uto hubs and they are full of grease, they need to come apart and be cleaned. The only lube in the auto hubs should be a good coating of ATF. To clean them, remove from truck, place in vise, use small long snap ring pliers and remove the small snap ring. Turn it upside down and the inner guts will come out. Put it back in the vise and you need to evenly compress the retainer ring that holds the spring. Use a 90° pick to dig the snap ring out of the groove in the hub casting (it's a bit tricky but not too bad). Pull the rest of the guts out. Wash everything in the varsol tank (including the casting). Replace the 6002 bearing if you need to. They are only about 6 bucks. Coat everything in ATF and re-assemble. Some grease on the splines is normal, but I would wipe of excess.
Old 02-25-2004, 09:01 AM
iamtheone iamtheone is offline
Send a message via AIM to iamtheone
Same problem on my ranger...
I would recommend NOT trying to fix the shitty automatic hubs. Instead, buy a set of manual hubs (milemarker makes a good set) and a conversion kit for them. It's not that expensive and a lot stronger than automatic hubs. To do the conversion...
http://www.therangerstation.com/howto_hubswap.htm
They are much better than my old automatic hubs, to engage the manual ones...push the button, get out and lock the hubs, then you're good to go and they WON'T disengage.
Old 02-26-2004, 12:37 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
If your going to throw money at it like changing the hubs. Why don't you just have a transmission shop diagnose it? Also, you ever go swimming to lock in your manual hubs? You know, when I'm in 4 feet of mud I'd rather push a button that go mud diving lol. Thats just me though. Also that motor on your T-case has a positioning sensor in it. It tells the computer what mode or range your in. And if those values don't match up to other values from speed signals, brakes and some others. That motor won't even try to fire up.
Stay cool
Old 02-26-2004, 06:42 PM
Just got Superwinch manual locking hubs a few weeks ago. What I do is keep the hubs locked in crappy weather and when I need 4wd I just push the button to engage the transfer case. I would assume that it would be OK to do. I dont have lockers up front, so I don't think I'm putting any stress on the front end while the hubs are locked and the T-case is disengaged. Works the same as the auto hubs I had. Is this OK or not?
Old 02-27-2004, 05:06 PM
SteveJH SteveJH is offline
Try this web stie. www.therangerstation.com This guy is a "rock crawler" nut, has alot of good info on all rangers from older to the new stuff. Helped me with my 86!
