Old 12-08-2003, 11:36 PM
wickedplastikman wickedplastikman is offline
b16 crx axle question
i just did a b16 crx swap. the axle on the driver side just doesnt seem to be working right. the wheel vibrates a lot when driving. i used the axle from a 91 teg and i inspected the axle before i put it on. they are fine.
the question is, the engine i bought came with the half shaft. it is a jdm. does that jdm half shaft not work right with our cars? is it a different size than usdm? is that the cause of my problem. should i replace the half shaft or am i wasting my time?
thanks
Old 12-09-2003, 10:53 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: b16 crx axle question
The JDm halfshaft will not work with USDM integra axles. You will need to get a USDM integra halfshaft. Also, there is a little dust cover/ring on the inside of the hub, that needs to be popped off as well.
Old 12-09-2003, 12:56 PM
thanks!! that dust cover, is that the dust cover for the brakes?
Old 12-09-2003, 01:10 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Re: Re: b16 crx axle question
Actually some JDM halfshafts do work. It's the JDM Y1 from the SiR that won't work with 90-93 integra non-ABS axles. The JDM S1, YS1, and J1 will work with the 90-93 integra axles (assuming it's a 5 speed intermediate shaft). Also, you can get a USDM integra S1 or A1 5 speed intermediate shaft, and that will work with the 90-93 teg axles.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 12-09-2003, 01:40 PM
kris's Avatar
Nope, it goes arround right where the axle goes into the hub.
Old 12-09-2003, 10:21 PM
so, could the problem have been that i did not pop off that ring on the hub the whole time? could that have been why the axle was just a little long causing the wheel to shake?
exactly how would the jdm halfshaft not work so i can tell if i need a new one?
Old 12-09-2003, 10:22 PM
and how wide is that ring?
Old 12-10-2003, 09:43 AM
kris's Avatar
3-4" in diameter maybe, and the actual metal is about 1/4".
Old 12-10-2003, 04:50 PM
does anybody know how much shorter the 86-89 integra axles are compared to the 90-93???
Old 12-10-2003, 07:48 PM
91civicDXdude's Avatar
im not sure as to the length, but the inner splines are larger to match the larger holes in the B series/ZC tranny
Old 12-10-2003, 08:02 PM
so then are you saying that it will not work with my 91 teg half shaft and my crx
Old 12-10-2003, 10:55 PM
Fishcat37's Avatar
if you have a 91 teg half shaft (assuming it's from a 5 speed), then use the 90-93 integra 5 speed non-ABS axles. simple as that. 86-89 wont work. i used hybrid 86-89 axles w/ SiR parts when i was runnin my Y1 half shaft. but just use the 90-93's w/ the intermediate shaft you have.
Appearance Mods:
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-MSD SCI-L ignition
Interior Mod
Former Cars
'94 Integra GS-R
'96 Camaro
Old 05-09-2008, 07:40 PM
vigalantyvillan vigalantyvillan is offline
Will the 90-93 teg axles work with the Y2 tranny?
