Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-08-2003, 05:16 PM
vinnyfh vinnyfh is offline
LT-4 knock mod
can someone explain what this is? and does?
is it the chip that goes on the bottom of the pcm? any benefits to a stock LT-1 with a few bolt-on mods? thanks
Old 01-12-2005, 07:52 PM
M.Works M.Works is offline
Re: LT-4 knock mod
Yes sir, about the Knock Module...
What it simply does is that it retards your ignition timing whenever your knock-sensors detect engine knock due many causes like high temp, bad fuel; and so on, however, engines when first made we expected to knock. So, when your knock module gets a signal that the engine is kocking it simply retards your spark plugs ignition time than normal, which in turn would reduce engine output and thus protect your engine from getting seriously damaged.
Old 02-14-2005, 04:26 AM
redimpss5 redimpss5 is offline
plus it only take 30 minutes to do. yes, it is worth doing!
american component's russian component's all made in taiwan!!
