Old 12-08-2003, 05:19 PM
kyduiguy kyduiguy is offline
jerking
I have a 1999 Suburban. About once a day it starts jerking, loses power and does nothing. But the check engine light does not come on and after this short intermission it runs normally. Is it transmission, fuel pump or fuel filter? Or something else?
Old 12-09-2003, 08:51 AM
jfmctlaw jfmctlaw is offline
Re: jerking
sounds like you have some heat related condition. Something should open or close, but doesn't immediately and it seems fuel related. I can't think of an electrical or mechanical failure that would follow this mode unless your tranny is spasmodically shifting up and down. Fuel filters don't usually clog and clear, they usually clog and shut the engine down.
Vary some parameters when it happens, increase/decrease load, shift in neutral and coast.
Old 12-09-2003, 09:11 AM
Re: Re: jerking
Thanks. It's been a real mystery because it doesn't always happen and when it does it goes away. Fuel pump and filter have recently been changed (but could still be problems); I figure if it was the tranny it would happen more often. Dealership doesn't have a clue because check engine light doesn't come on.
Old 12-11-2003, 03:40 PM
dirty dan dirty dan is offline
Re: jerking
How hard is it bucking? Torque converter failing or TCC acting up can cause similar problems.
Old 12-11-2003, 05:30 PM
Not real hard...sorta feels like the tranny disengages or the engine isn't getting fuel. But the fuel filter and pump have both been recently replaced.
Old 01-18-2004, 12:41 AM
Ironmen Ironmen is offline
Any other ideas? Have same problem!
Old 01-18-2004, 05:45 PM
Disconnect TCC Solenoid from Transmission and see if problem clears up.
Old 01-23-2004, 07:09 PM
Re: jerking
Can I do this myself or do I require a mechanic?
Old 01-23-2004, 08:19 PM
Tat2dBrownDude's Avatar
Tat2dBrownDude Tat2dBrownDude is offline
Re: jerking
Just climb under and do it yourself, very easy.
"The Anti-JEEP"
Old 01-24-2004, 10:55 AM
Re: jerking
Where is TCC Solenoid located under the truck?
