Old 12-08-2003, 03:19 PM
Artem1985il's Avatar
Artem1985il Artem1985il is offline
HELP!!! SAS Kit
I just got the 350Z body kit from SAS. I haven't used anything like this before and I don't really know how to 'work' it.
1.What do I use to cut out the parts from the original car.
2.What do I use to attach the new parts to the body? Cement/super glue/tape??? (I don't have any putty)
3. Any thing else I should know? Anything about removing the moldings? (Tons of em)
Thanks.
P.S. Check out the progress thread for the car this kit is for, the link in my sig.
Recently completed:
Nissan 350Z streetDRAGON (progress HERE, finished HERE)
Old 12-08-2003, 04:02 PM
AE86er's Avatar
AE86er AE86er is offline
I've heard cotton thread works very well- just take it slow- back and forth, back and forth and the heat/friction will nicely cut the plastic along your chosen path.
Hopefully others can help you with the attachment questions...
Old 12-08-2003, 04:03 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Using a razor blade, make many many many many shallow passes along the panel lines between the panels you wish to separate. Or, if you have one, you can go at it with a Dremel until most of the material is gone and sand the rest away. Thats what I did with my S2000 (thread whoring here and here)
To attach the resin, use superglue or two part epoxy. Superglue should be fine, but you may have to reinfore the joint with stryrene strip or sheet, but Chris makes good stuff and it should have reinforcement built into the resin parts, so no problem.
Other things you should know: Sanding resin generates toxic dust! Do not sand resin without a mask of some sort! The $1 paper masks from Home Depot that cover your nose and mouth should be fine. I can't tell you how many times I've worked with resin and had a sore throat/nose for a couple days after. Don't repeat my mistake!
-Also, wash the resin thoroughly before paint. The mold release compounds on resin usually stick to the resin very well, but not to paint. If you don't wash resin, the paint will fall off later. I don't know what Chris does, but better safe than sorry.
-Also, for this mod, it might be best to cut the hood out, replace it (don't glue the front edge) then cut off the front bumper and replace that, and not to both concurrently. If you do, the Z's body will be very fragile and it will be extremely easy to break the A-pillars, which can be disasterous.
Have fun!
Old 12-08-2003, 04:19 PM
Jay! Jay! is offline
Horizontally Opposed
How to - Opening hoods, doors, etc. - by flyonthewall
Hierarchy of Subaru:
(Click to see mine!)
coilover kit help suzuki19 Performance 0 05-16-2010 01:23 PM
SAS kits are all for tacos up to 95?? sinfull90 Tacoma 1 08-02-2006 12:53 AM
SAS-Kits should be forbidden andreasgtr Car Modeling 4 11-12-2003 02:33 PM
Are those Tamiya kits or SAS kits? AE86 Kid Car Modeling 8 05-08-2003 03:09 PM
I need help locating kits/parts for my 99 camry!! aznguy119 Camry/Camry Hybrid/Vista 6 08-08-2002 06:04 AM
