Go Back   Automotive Forums .com Car Chat > Mercedes-Benz > E-Class
Old 12-08-2003, 03:09 PM   #1
tdicar
Help removing driver's door panel and window regulator
Can any body help here?
tdicar is offline   Reply With Quote
Old 12-09-2003, 10:40 PM   #2
MB tech
Re: Help removing driver's door panel and window regulator
Need more info what year car and front or rear door?
MB tech is offline   Reply With Quote
Old 12-10-2003, 03:44 PM   #3
tdicar
My fault - Drivers door lhd (US spec) 1995 E320 wagon
Old 12-10-2003, 05:23 PM   #4
MB tech
unscrew the door lock button pry the trim off around the seat switch and door handle. There are two screws holding the power seat switch in take the out and remove the switch. Push the door handle torwards the front of the door it should slide out and remove the latch rod from the assembly. There maybe a screw or two under the armrest. Remove the chrome trim around the door latch. It may be hard to remove the upper part of the panel at the lower window moulding so you may want to pry it up with a plastic wedge or a screwdriver (with a cloth underneath) first just to loosen it a little. And pull up on the rest of the panel. Then remove the plastic underneath (you can throw it away if it rips). put the window down until you can see the slide on the regulator there is a black plastic clips on the metal portion of the lower window bracket (on the window). Remove the black plastic clip on the bottom. The regulator shoud just be held on with 10mm bolts I think 4. Usualy indicated with a red dot on the head if nobody was in there before. Then just remove the regulator with the motor.
How to remove driver's kick panel-2003 Grand Prix SE reen910 Grand Prix 1 04-24-2009 06:03 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 08:08 PM
92 Camry Drivers door panel and window..help please... hwyflier2 Camry/Camry Hybrid/Vista 3 07-17-2006 10:43 AM
Need door panel, and window. Passenger side Rcme86 Lumina 0 07-24-2005 06:39 PM
