| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
OK, which is better and in what respects.
A Cast Iron tubo manifold A Steel tubed Turbo manifold An Iron tubular manifold http://www.revhard.com/manifolds.html also why do they run the exhuast that powers the turbo thru a different hole than the regular exhaust hole? why not just attach the turbo to a normal header like a dc sports header, it seems like the turbo would spool quiker this way. I am wondering this because my idea is to get an H22a and rebuild it with stroker kit to 2.5 liters and cmpression ratio of 9:1 then put a quick spooling turbo on it and run 20ish psi, if possible, will have to custom build turbo kit cus nobody makes a decent one with engine management thoughts would be appreciated Thanks
Current ride: 92 civic lx sedan, stock as it gets and stayin that way! Looking for: 4th gen(93 - 95) Prelude VTEC. Plans for it: Rebuild the engine and the car, then turbo it with a disco potato(gt28). ![]() Then kill all the mustangs and camaros i see If you are bored IM (or email) me: AIM: Jermonsta Yahoo: Jermonsta MSN: [email protected] Quote:
help
shoud i post this elsewhere?
A Steel tubular manifold is the best for power and spool speed, plus it weighs less than a iron tubular design. But, you will usually have to go with custom tubing if you go this route. The cast iron design, i have heard, is better for daily drivers, (it doesn't crack as easy and does not place the weight of the turbo in an awkward position) which is something i would like someone to clarify. If you were to mount the turbo on the tubular designed manifold and support the weight of the turbo with brackets mounted to the engine, would it be suitable for the street?
94' Del Sol VTEC (B16A3) SOLD. Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles. |
Re: Turbo Manifold Questions
Interesting conversation. Honestly.. not all stainless steel is good for turbocharging. I dont believe in using ss because of heat transfer, but that is my opinion and from select few.
You will run into just as much fabrication/money in making it work from a header...and that means just as much money would go into making one as to buying one made specifically for T3 turbo's with external wastegates. If you wanted to do the fab yourself... use the "log design". Just keep "optimal air flow" in mind while fabbing it. Jet coat the cold rolled steel when all is done and ready to bolt on.
Dealer for Turbonetics products...cant beat our price! Dealer for SCT......fine tuning software T3/T4e, super series, Hybrid, stage III Turbine $650.00+tax T3/T4e Ball Bearing, Hybrid stage III Turbine $1,050.00 +tax Turbonetics EVO wastegates...$200.00!!! Turbonetics Raptor Bypass Valves Turbonetics Turbo kits for Civic's, Preludes, GSR's for $2,999.00!! Spearco IC's from $225.000 PHONE #: 937-336-1462 ask for Stephen N Brown ********HAPPY HOLIDAYS******** |
i wasn't necasarily talking about Stainless. In my opinion, i would get a ceramic coated tubular manifold. $$$ (register closes)
Yeah i know..i just through in my 2 cents worth on that one. But yes tubular design cold rolled steel manifold. Especially equal length...
i had a custom made one if u wanna look at it
www.cardomain.com/id/sheldong_69 |
Cant see to close but, it seems like a very well made manifold!! Good for you!
Nice car by the way!!
stainless steel tubulars crack all the time. The weight of the turbo on the manifold is too much and you must support it against the engine with brackets. however a good equal length will flow much better and give you more gains. Iron tubular is a little stronger but heavier but still has welds that will crack (cracks at weakest point). Cast wont give you the best gains but it doesn't really crack often. This is the one I recommend, supposedly revhards cast still flow really good.
