Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 12-08-2003, 11:35 AM
Dans Collision Dans Collision is offline
97 villager tranny problem
I'm working on a buddy's 97 Merc Villager with 87,000mi. Check engine light came on after a stall out while sitting idle. DTC p0732 p0733 - indicates 2nd and 3rd gear ratio incorrect. Sounds like a sensor problem to me. anyone have experience with this particular problem?
Any help would be appreciated
Dan
Old 01-12-2005, 06:43 AM
airhigh airhigh is offline
1997 Villager Tranny
I had that problem and I took my vehicle to the dealer and it turned out to be Exhaust Gas Recirculation (EGR) sensor/tube it cost about $400 to repair.
Old 01-12-2005, 08:01 AM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Re: 97 villager tranny problem
Tps sensor also controls tranny shiftting patterns. I have one if you need it. OEM in box.
Old 01-21-2005, 12:58 PM
JEEPMAN33 JEEPMAN33 is offline
Re: Re: 97 villager tranny problem
I need one How much?
reply to:
[email protected]
Old 08-04-2005, 08:34 AM
alkaz alkaz is offline
Re: Re: Re: 97 villager tranny problem
Did you replace the TPS sensor, and did it work? My 1998 Villager stalled after sitting idle. Then the Service Engine light came on - the DTC Code was P0732 - 2nd gear ratio incorrect. Sounds like either EGR or TPS. Thanks for any help.
Old 01-17-2006, 04:07 PM
IH8SPM's Avatar
Yes I still have it. just post if you need it or PM me here I check every day or so. I did miss the post from last year sorry
Old 04-05-2006, 08:52 AM
molatech molatech is offline
Do you know if the TPS would also cause the trans to downshift? It seems like it drops from OD back a gear and if I push slighlty down on the accelerator it shifts back up and when I left off slightly it shifts down again.
Of course this is noticeable only over 40 MPH or so after the OD gear kicks in.
This is a 94 with 255k on it and has performed almost flawlessly since new.
Thanks.
Old 04-06-2006, 07:27 PM
IH8SPM's Avatar
It sounds like you have tranny problem at this point. A sound would indicate it to be a internal problem not like when the TPS is bad it just gives small burst of RPM or will hang up your OD if its really bad but you will get no thumps or clunks etc.
Old 04-06-2006, 09:20 PM
No sounds from trans at all. It just randomly downshifts itself from OD to 3rd. I noticed if I give it a bit of throttle it shifts back up...when I let off it shifts back down. I thought possibly vacuum...now I'm not sure if tps will cause that.
