Old 12-08-2003, 06:07 AM
aces1980 aces1980 is offline
rear disk conversion?
will the complete rear disk conversion of a 93-97 Honda Del Sol fit in my hatch? if so what exactly do i need to pull from the car. please let me know asap thanks
Old 12-08-2003, 10:13 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
The trailing arms should fit just fine. The 4g rear suspension is the same as the '94-99 Integra, which is the same as the '93-97 Del Sol. My buddy has a '94 Del Sol VTEC & he swapped his entire suspension with an ITR suspension. It was just a matter of taking off the old stuff & replacing it with the new. So the Del Sol stuff should work just fine on a 4g (or 2g CRX). However, I'm not sure about the e-brake cables.
You'll need to pull the rear trailing arms, & e-brake cables (I'd pull 'em, just to see if they work). You won't need the LCA's...they're the same as ours.
Old 12-08-2003, 01:04 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
I thought it was just 90-93 teg rear disks that fit our cars? Not saying your wrong just that I have never heard that the newer teg brakes are a direct replacement for our drums.
I'm Jordan
My car is the ugliest one on this board
Old 12-08-2003, 01:17 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: rear disk conversion?
If you have a DX and are planning to get a rear sway bar, you will need the LCA's cause the dx's don't have the mounting point for it. That's what I'm going to do when I do my brake swap, cause I'm planning on getting a sway bar.
Old 12-08-2003, 01:33 PM
hey thanks CZ-R! i am going to put those on a 91 si. well i won a ebay auction for what i think is a good price for a complete swap. check this out and let me know if i wil need anything else
item2446275250
Old 12-08-2003, 02:32 PM
CZ-R's Avatar
I'll check it out when I get home. eBay is a at work
The only other thing I can think you might need is the proportioning valve, but I'm not 100% on that. I'll know more when I get home & can check my manuals...
