Old 12-08-2003, 03:14 AM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Question How much are Turbos there
Just wondering how much they go for there...
Not too bad here.
Yeah yeah I know it looks like grandpa's but wait til I put the LT1 in it
Old 12-08-2003, 01:13 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: How much are Turbos there
where is there?
Old 12-08-2003, 04:10 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
It all depends on what you want. I have a te-60 from precision turbo&engine, It cost me $675.00. Here is a link to the diffrent turbos and the prices that they are over here from Precision turbo and engine.
http://www.precisionturbo.net/produc...=Turbochargers
I hope this anwsers your questions.
Andy
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-08-2003, 06:18 PM
Vlad_Tepes's Avatar
There being the states....
Hyps thanks man looking into it
Old 12-08-2003, 06:38 PM
Hypsi87's Avatar
no problem man. Any questions about turbocharging just let me know. I'm not an expert but I would think I know more than the avrage bear.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 12-08-2003, 06:50 PM
Vlad_Tepes's Avatar
LOL @ Hyps...
Well I'm looking to put a turbo on a LT1 for my Uterus...
How hard is it to get all the stuff to make it work?
Old 12-08-2003, 09:51 PM
Hypsi87's Avatar
getting a turbo and the wastegate would not be a problem I would suggest a big shaft turbo. With a bigshaft turbo you do not need a blowoff valve, the shaft and bearings won't even notice the compressor surge. The LT1 is prettymuch a bullet proof block. it would be wise to drop your compression to about 8-8.5to 1, and maybe a cam that is ground for a turbo engine. Your biggest challenge is getting the piping for the exaust and the compressed air circuit. I would suggest intercooling it and perhaps alcohol injection. seeing that your doing this to a truck you should have plenty of engine room. BTW what kind of truck is that?? how much boost do you want to run??
later
Andy
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 12-09-2003, 02:37 AM
Vlad_Tepes's Avatar
Andy
The truck ( more like an El Camino) is a Holden Ute
We call em utes or uterus they bot carry stuff you know...
Anyway going to leave the uterus and LT1 pretty stock was going to drop compression a bit. looking to get about 10 psi of boost nothing to extreme. it is my daily and just like that free horsepower idea esp when already rolling..
Not looking to be the fastest just hold my own and get great dependability til I get myself a real job
Old 12-09-2003, 09:35 AM
StingRay_68 StingRay_68 is offline
"looking to get about 10 psi of boost nothing to extreme"
Yeah, I don't want too much money for christmas, around 3 million should do it.
Expect to get about 60% power gain with 10PSI heh.
Old 12-09-2003, 06:52 PM
Vlad_Tepes's Avatar
Sting...
Shhhhhhh dont say nothing the wife reads this too..LOL
ok maybe 5 to 6 now....did a little more reading
Old 12-09-2003, 09:07 PM
krebs128 krebs128 is offline
Send a message via AIM to krebs128
y not 10psi? they got internally stock impala ss's w/ LT1s running 12psi, and getting in the 12's too. vlad, are u thinking of twin or single turbo setup? i'd suggest a twin setup for any v-8, one turbo on each exhaust manifold.
Old 12-09-2003, 11:15 PM
Hypsi87's Avatar
id go single if you just want to run 10 psi, wicked crazy spool up plus the twin setup is another 700 bucks at least. and I would look into a TE-44 if you want to run 10PSI. I got the compressor map somewhere on this damn computer I just need to find them. I had a TE-44 on my GN and I still have it. I upgraded to a TE-60 but im thinking about going back to the 44. It is such a street friendly turbo that is hard to resist. go to turbonetics website. they have two types of ADJ. wastegates. The deltagate and the race gate. I run the Deltagate and it is nice because you run vacume lines into the cab of your truck and hook it up to a regualtor. your boost is adjustable from inside the cab. If you drop the compression that block will handle more than 12 PSI. the trick to running high boost levels and doing it safely is to figure out a way to watch your knock sensor. pre-deationation is the number one killer for all forced induction engines. If you are going to run pump gas only then I would extremely reccomend an alcohol injection kit, just some added insurance for the headgaskets.
Don't worry about how much max boost you want to run. The beauity behind a turbo is that with a twist of a dial your boost is different. you just want to have a range so yo can pick the most effecient turbo.
Andy
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 12-10-2003, 12:00 AM
Vlad_Tepes's Avatar
Andy,
Thanks for the input...
going to have to email you back and forth on this stuff...
What the hell is the acohol injection stuff and what does it do?
Old 12-10-2003, 12:19 AM
Hypsi87's Avatar
alcohol injection is a kit that injects atomized denatured alcohol into your compressed air charge when under boost. Have you eve spilled alcohol on your hand and you hand got real cold? it's the same theroy when the alky hits the hot air it vaporizes sucking heat out of the charge air. plus alky is rich in octane. with my car on 93 octane pump gas I can run 17 PSI without alcohol and without knock. when the alky kit is turned on I can run 24+ lbs of boost with the same pump gas without knock. I think that figures up to about 100 HP just because of the alky. also my sugestion for the tubo size I think might be wrong. a 44 might be a tad too small for a lt1, I have ti start thinking like a mid american redneck with his 350 chevy and not like a civilized person with his big comfortable buick . Ill have to look at some compressor maps to tell though.
Andy
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 12-10-2003, 12:42 AM
Vlad_Tepes's Avatar
Ahhh ok...
well I let me know what you come up as I look for stuff here...
I lost all my websites for tubo stuff there...
Check these out
http://turbotech.com.au/index.htm
http://www.turbofast.com.au/welcome.html
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
