Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 12-07-2003, 11:38 PM
kissey kissey is offline
timing belt diagram
OK, I had posted earlier that I couldn't figure out what was wrong with this 95 mercury mystique. So I got off my lazy butt and found the timing belt is broken. I am hoping I don't have to remove the engine mount to get to it, but it is not looking good. Does anyone know of where I oculd get a diagram of the belt or the procedure involced in changing this out. And if I have to remove the mount, how can a gal with a walmart toolkit hold the darn thing up while I work on it. We are talking backyard-backyard mechanic. But I will be damned if I don't fix this and prove to all the "guys" I could. Thanks for any replies.
Old 12-08-2003, 10:25 PM
Culookin Culookin is offline
Re: timing belt diagram
What motor is in it? 4 banger or V6?
Old 12-08-2003, 10:27 PM
Actualy here you go! This will help with just about anything you need.
http://www.cybrrpartspro.com/Manual%...delLookup.html
Old 12-10-2003, 07:34 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
the timing belt diagram should be on a sticker underneath the hood of the car. Look on the front of the frame under the hood or the passenger side strut tower.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
