Old 12-07-2003, 09:32 PM
justchad25's Avatar
justchad25 justchad25 is offline
Send a message via AIM to justchad25
bypass for keyless entry
anyone know how to bypass the radio so i can have my keyless entry back for my 1997 honda civic? i have an aftermarket radio and now it doesnt work
Old 12-08-2003, 10:30 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
Is it an aftermarket keyless setup? Also check your fuses if you haven't already. Your keyless quit working when you put your radio in?
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 12-09-2003, 02:43 AM
k67p67 k67p67 is offline
The only way to retain the factory KE function in that car is to retain the stock HU. There is plenty of room beneath the HU location to bury the old one.
SoundDomain link (system pics)
~ALL SHOW - NO GO~
Old 12-16-2003, 05:40 PM
justchad25's Avatar
Re: bypass for keyless entry
yeah ive been told this but i wanna know where i can find a harness that i can connect my stock HU in with the AM HU
Old 12-16-2003, 07:07 PM
Re: Re: bypass for keyless entry
Just leave the stock harnesses plugged into the OEM HU. Tap into those wires for 12V+, sw.ign., ground, and ill. Cut the 8 speaker leads from the OEM harness and solder/splice them together with the 8 speaker leads from you aftermarket HU. Your OEM KE should function normally. I recall having to tape a piece of cardboard over the display of the OEM HU to keep it from casting an ugly glow from behind the dash.
~ALL SHOW - NO GO~
Old 12-29-2003, 09:22 AM
justchad25's Avatar
thanks a lot
Old 12-31-2003, 09:22 AM
civic98mi civic98mi is offline
much easier way...instead of plugging your factory unit back in and leaving it sit behind your dash, look for the "GREEN" plug that you unhooked originally from the head unit. Pull it out as far as you can to access the wires. Look for 2 wires: red/green and green/black....splice these two wires together and it should work. Although i'm not sure if it fixes the keyless entry, i bet it does, but I haven't tried, since my car didnt have it. It does for sure fix the dome light problem.
