Old 12-07-2003, 08:34 PM
gen2tegls's Avatar
gen2tegls gen2tegls is offline
Send a message via MSN to gen2tegls
Question how much boost
how much boost is the stock boost on a 90-94 dsm and what can you run safley on stock internals? and what would be a good way to crank your boost up safley like a bigger intercooler etc..
Old 12-07-2003, 09:49 PM
kjewer1 kjewer1 is offline
AF - Advisor
Stock boost is around 11 psi. Poeple run over 30 psi on stock internals (90-92 "6 bolt" motors) but the car has to be very well modded to survive that. I wont go through the whole list again, since I've answered this so many times here. Search around, or go to the POSR site in my sig, and look on Chads page. He ran 31 psi on a completely stock motor and put down 497 whp. He has all of the mods one would need.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-07-2003, 10:16 PM
gen2tegls's Avatar
Re: how much boost
(90-92 "6 bolt" motors) what about the 93-94 whast the difference
since I've answered this so many times here" could u give me a link to where you might have posted on this topic before please
i watched your videos of ur gsx and that thing flys ur launches are soo nice and fucking fast
Old 12-07-2003, 10:49 PM
gen2tegls's Avatar
i think i might want to run around 20 psi and do these mods what do you think
-Intake Pipe and Filter
-Intercooler Piping
-Performance Clutch
-O2 Sensor Housing
-Fuel Pump
-Exhaust Manifold
-High Flow Downpipe....3 or 2.5 im not sure
-high flow muffler and resinator
-test pipe
and a boost controler and a boost gauge to regulate my psi what
got n e suggestions and what do u think else is necessary or isnt
Old 12-07-2003, 11:18 PM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
Re: how much boost
By internal mods usually people mean pistons, rods, crank. These are the critical elements for surviving high boost.....or you may have parts looking like this
haha...detonation rules
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 12-08-2003, 12:19 AM
AF - Advisor
Re: Re: how much boost
he 90-92 motors a re 6 bolt motors, and the 93-99 motors are all 7 bolt. The 7 bolts came wiht smaller rods, so they generally cant take as much power on stock internals. I would be happy to do some searching and find you some links where this has all been posted, but thats your job You dont even have to search. I wrote up a nice mod path yesterday, so it should be on the first page of threads.
Kevin Jewer
Old 12-08-2003, 12:22 AM
AF - Advisor
Re: how much boost
-Intercooler Piping
-Performance Clutch
-O2 Sensor Housing
-Fuel Pump
-Exhaust Manifold
-test pipe
You will be able to run 20 psi on those mods, but you will need race gas, which also requires fuel control to compensate ofr the higher specific gravity of race fuel (or you will be running rich). To run this on pump gas, just add a good FMIC. A larger turbo will make more pwoer at the same 20 psi since a 14b is at its limits at 20 psi on pump. But it will work. Datalogging is almost required though, since you're pushing the limits of the setup. Better safe than sorry. There are some good threads in the last couple days about fuel control and datalogging, be sure to check those out. Hope it helps.
Kevin Jewer
Old 12-08-2003, 12:33 AM
gen2tegls's Avatar
thanks man right now im tied up between a 93 gsr a 93 240sx fastback or a 90-92 talon,eclipse,laser i think im gonna go dsm i just wanna get a blunt idea of what they are capable of
