Old 12-07-2003, 07:48 PM
xsimpleaznx's Avatar
xsimpleaznx xsimpleaznx is offline
how to install hood pin
does anybody know how to make a hood pin for an alarm? is it a one or two wire hook up into a compressed pin? do u splice into siren or a shock sensor or something? i want to add some pins to my hood and trunk to add some safety. i have a viper 500esp with shock and proximity sensor
Old 12-08-2003, 03:42 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: how to install hood pin
hood pins = teh ghey
Old 12-08-2003, 10:38 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
the grey wire yes. But doesn't the 500esp have a remote start on it? It has been too long since i have installed one of these. Anyhoo some of the older alarms with r/s the hood wire was for the r/s portion and didn't always trigger so if this is the case. Try going to a local shop and getting some mercury tilt switches. They are very simple to install and run the output to the instant grnd trigger green i do believe or just tap the wire that goes to the corresponding light on the cluster which ever you think is easier... The trunk is the same way.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 12-08-2003, 10:49 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
I 2nd the mercury tilt switch. Mostly because it will never fail like a pin switch. The pin switches will corrode and stop working.
