Old 12-07-2003, 07:09 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
projector corner light clash
hey i juss bought some black JDM projectors and i was wonderin if any1 knows if they do make black corners for 90-91 civic or if 88-89 corners will fit with a lil modification. clear corners will look shitty wit black pro's. if im shit outta luck with both options how would amber jdm corners look? thanks ppl
Old 12-07-2003, 07:46 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: projector corner light clash
Yea man, theres 90-91 black corners. Look on ebay, theres a few (not right now actually) but usually theres a couple up for sale. Good luck.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-07-2003, 07:48 PM
travagliante's Avatar
travagliante travagliante is offline
I believe that they will fit fine but you need to switch the brackets and use the ones for the 90-91 that are already on your car....
Hope this helps
Old 12-07-2003, 07:57 PM
do you mean the mounting bracket on the back of the corner lights i got now? Dayum u CRX guys are lucky to have those clear JDM black corners!
Old 12-07-2003, 08:00 PM
Yeah you just have to swap the brackets from the ones you have know. Im pretty sure it will work. It worked for my friend.
Old 12-07-2003, 08:20 PM
im guessing it would be a bitch to take off the backing of a corner light?!?! they seem fused together, but hey im willing to try it... couldn't hurt
Old 12-07-2003, 09:13 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Just use a Black transparent paint from a hobby store on some clear corners. I bought mine for like $12, I can't remember where. They have some on Speedpeople.com for $15 though.
Check out my car here My 91 Hatch
Old 12-07-2003, 09:51 PM
anybody try to use crx corners on there civi? i could use some opinions on what to do, i got jdm black projectors and i need suttin to kinda look good with it other then clear corners. thanks
Old 12-08-2003, 12:27 AM
Clear Corners Tinted Black!
Old 12-08-2003, 10:30 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
It's amazing what you'll find if you do a search...
http://www.automotiveforums.com/vbul...=black+corners
Old 12-08-2003, 03:51 PM
damn my pc is being retarded! can someone please send me those pics through email? [email protected] thanks alot
Old 12-08-2003, 04:05 PM
CZ-R's Avatar
Your computer is not retarded....that thread is over a year & 1/2 old. Here's the pics:
That's my car in the pics. If the old thread didn't explain the process well enough, feel free to PM me with any questions...
Old 12-08-2003, 05:13 PM
CZ-R, I appreciate ur help. I got the same projectors u have with blue ION projector. I juss got um off ebay the other day so they should be arriving soon. Your corner lights turned out great. I dont have a dremel tool nor do i wanna destroy the lenses by boiling um.. got any other ideas? and once i get the lenses off juss using fine grit sand paper and then painting the inner housing glossy black would be a ok plan? thanks alot again for ur help
Old 12-08-2003, 05:44 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i put CRX corners on my hatch. its a lot of work, but mostly bolt on. http://www.automotiveforums.com/vbul...d.php?t=100654
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-09-2003, 08:25 AM
CZ-R's Avatar
Re: Re: projector corner light clash
Yeah, but... You also had to replace the fenders. Why do that just to be able to buy the black corners?
And yes, I did my lenses with a dremel (worth every penny - get one ). I just used a cut-off wheel & cut the lenses apart from the back side. Grid off all the 'chrome' inside the lense, paint black (I used gloss black - just because I thought it would reflect better). Oh, and I used black RTV to glue/seal the lenses back together.
As for the "JDM" amber lenses... I just used amber bulbs in my corners (after converting the corners to black) & at night they look just like the amber lenses... I'll have to take a pic...
