Old 12-07-2003, 04:23 PM
travagliante's Avatar
travagliante travagliante is offline
Sohc Vtec Is This A Deal
Hey eveyone.
Okay here is the deal, my d15b2 with mpfi had a little problem and it kicked the bucket.
Well i really dont have a backup car so im borrowing my moms till i can get it fix. Well anyway a guy is willing to sell me a 92-95 obd1 SOHC VTEC engine for 425.00 with 5spd transmission. NO ecu. Does anyone think this is a good deal???? I think it is and it will sustain me for like 6 months till i go bigger? Do you think that thats a good deal????
Thanks
Andrew
all i think i need to do is obd1 to obd0 and wire vtec
Is the tranny hydraulic.
If yes would it be easier to use my 5spd lx one??
Old 12-07-2003, 04:46 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Sohc Vtec Is This A Deal
Well, for that price, why dont you get the JDM D15B (sohc vtec) which normally has less miles, has a warranty, etc.
Yes the tranny is a hydro, if it is the same one that came with the car.
Old 12-07-2003, 04:53 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
I would go for it (if it's a D16Z6). If the problem with the D15 was in the MPFI I would suggest against it as you will need all the MPFI parts to run your current ECU with the new engine (or you could convert to OBD1 and find an ECU for it).
DOHC ZC 89 DX HATCH
Old 12-07-2003, 05:20 PM
Well the only reason i was interested in it was because the guy lived close to me and he would deliver. Its a true sohc vtec. The engine block is stamped ZC and it was a front clip that had 47xxx on it.
Oh and i was going to convert to obd1.
ANy thought please??
How hard is it to convert to a hydro, the engines not a hybrid its a true sohc zc... Or would it be easier to use my d15b2??? tranny??
Old 12-07-2003, 05:22 PM
kris's Avatar
I didnt know the ZC came in vtec form. The D15B is mpfi as well.
Old 12-07-2003, 05:23 PM
HERE IS THE EBAY LINK:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2446621281
Old 12-07-2003, 06:11 PM
bump anyone i need to know because i need to tell him yes or no by tonight!!!!!
Old 12-07-2003, 06:13 PM
spongerlbc's Avatar
You can sell the hydraulic tranmission on ebay and easily get at least $150 for it. I paid ~$850 shipped for a DOHC ZC and low mileage SI tranny (they were from different places so shipping sucked) so I think $425 and free delivery is a steal.
DOHC ZC 89 DX HATCH
Old 12-07-2003, 06:21 PM
How much of a power decrease will be about with using a lx 5spd tranny.
Im only using this for ease of install.
Old 12-07-2003, 06:59 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Okay, I hate to be the bearer of bad news, but first off, there was no 92-95 ZC engine in a Honda. The ZC came in the 86-87 (Chassis code AT) JDM Civic Si, the 88-91 (Chassis Code EF) JDM Civic Si, 86-89 (Chassis Code AV) JDM Integra, and the 90-93 (Chassis Code DB) JDM Integra. Also, the 85-87 CRX Si and the 89-92 CRX Si1.6/1.6i had the ZC too. All the ZC's but the last one (90-93 JDM Integra) where rated at 129HP@6800rpm and 106 ft/lbs@5700rpm with a Compression Ratio of 9.6:1. The 90-93 JDM Integra ZC was rated at 119hp@6300rpm and 105 ft/lbs@5500rpm with a Comperssion Ratio of 9.0:1. The ZC found in the 86-87 and 88-91 Civic was 1595cc, the one found in the 86-89 and 90-93 Integea was 1590cc. The 86-87 Civic Si and 86-89 Teg came w/ a CG tranny. the 88-91 Civic Si came w/ a L3, and the 90-93 Teg came with a S1, A1, or J1 tranny. Maybe the SOHC Vtec ZC was the one found in the Teg. If you can get the tranny code it might help with the source of your ZC. I have seen the SOHC ZC listed on ARDperformances website before, but not reallyu anywhere else. I have never seen one in real life. I know most ZC motors where a non-vtec DOHC desgin @ 1595cc, so I am guessing the 1590 ones where the one you where looking at. I personally wouldn't get it. It doesn't feel right to me. Plus, you'll need to buy the proper Vtec ECU. Anyways, there's info on ZC's for yea, hope it helps.
Old 12-07-2003, 07:12 PM
the engine block has zc stamped on it??? ANY HELP?? LOOK AT THE EBAY LINK WHAT DOES IT LOOK LIKE OR IS???
Old 12-07-2003, 07:28 PM
Honda God
well...http://www.nippon-motors.com/honda.htm shows it as a D16A6...a SOHC non-Vtec motor in the 92-95 JDM civic.....it's listed as "ZC/D16A6."
However, http://www.ardperformance.com/cgi-bi...l?action=index shows a SOHC Vtec "ZC" from a 92-95. My best guess is this.....that motor is probably a D16Z6....just like the SOHC non-vtec ZC is a D16A6......I am guessing it's from a 1.6 SOHC Vtec JDM Civic, and is probably what is called the D16Z6 here...either that or they have mini-me swapped the D16A6/ZC motor...
Sorry I am un-able to be more clear.
Old 12-07-2003, 07:44 PM
THATS OKAY. THE PIC LOOKed like it was a hybrid between a d15b vtec head and a d16a6/zc block, thats why i thought it was stamped zc on the block.
Old 12-07-2003, 08:09 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
SOHC VTEC PGM-Fi
16V SOHC with VTEC, Programmed Fuel Injection.
Max Power : 130ps.
EG-series Honda Civic Ferio EXi (coded as E-EJ3).
I found this at aisa.vtec.net
Check out my car here My 91 Hatch
Old 12-07-2003, 08:34 PM
Honda God
Originally Posted by Dumped91Hatch
SOHC VTEC PGM-Fi
Max Power : 130ps.
Good job researching that. We hammered this out quick. It looks like my suspision from my last post was correct...that the "92-95 JDM OBD-I SOHC VTEC ZC motor" is indeed the USDM 92-95 OBD-I SOHC VTEC D16Z6 motor. Same displacement, same bore and stroke, and hp and torque at the same rpm. Both 4 cylinder 16 vavle sohc. Kind of confusing, and misleading, since most ZC's are thought to be the DOHC design by most ppl. I think it would have been easier to code both D16Z6 in both the US and Japan. It seems to be the same motor. Oh well, lol.
