Old 12-07-2003, 02:53 PM
gerch gerch is offline
rear window lock(91 s10 blazer)
does anyone know if the button on the dash that unlocks the rear window on the lift gate(91 s10 blazer),has a fuse.Mine stopped working,am trying to figure out how to fix...............
Old 12-08-2003, 07:46 PM
krazybaddude krazybaddude is offline
It could be a bad solenoid in the tailgate. Have a friend push the button, while you check for power at the solenoid. If you have power going to it when the switch is pushed, then get a new solenoid.
If you dont have power, then it could be a number of things. I'm not sure if there is a fuse or not, but you should go through and check all of the fuses anyway, just to be sure. May also be a bad button.
Good luck!
-Dan-
