Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-07-2003, 11:31 AM
MGAUTHIER MGAUTHIER is offline
Service Engine Soon ??
My Service Engine Soon Light Is On And Will Not Go Away. I Reset The Computer, And It Is Still There. Where Do I Need To Go And What Do I Need To Do.
Old 12-07-2003, 02:15 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Service Engine Soon ??
The PCM has seen a problem with the emissions system or a related componant and has set a code and turned on the SES light.
What year,make and model is your vehicle? This will help in determining if your vehicle is still under warranty or not.
If your vehicle is not under warranty, you can go to Autozone or some other parts store and have them pull the code for you or you can purchase a code reader and do it yourself...the code or codes will give you an indication on what is going on and start the diagnostic process
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-09-2003, 10:22 PM
JeffL. JeffL. is offline
You are correct, AutoZone will do the diagnostics for free and might even offer some advice.
Jeff
Old 12-10-2003, 04:18 PM
doccmajor doccmajor is offline
Send a message via AIM to doccmajor
AutoZone can test but they arn't always the most helpful...
Ihave a 99 Jimmy that had the SES light come on today, brought it in there they got the code but couldn't tell me what it was for sure, the code is P0446
They had me check the gas cap but that was it, and I'm not really sure they knew how to reset it cause the light is still on... Does anyone here have any idea what the problem could be?
Old 12-10-2003, 04:46 PM
The only thing I could find on the internet was:
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
I'm not sure where to go from here. I hope someone else can lend a hand.
Jeff
Old 12-12-2003, 06:25 AM
GMMerlin's Avatar
I know stuff
The P0446 is the code that is stored when the PCM sees a problem with the vent system during the self test....basically the EVAP system won't release vacum fast enough.
There are many things that can cause this problem, plugged vent valve, restriction in the vent lines, purge solenoid leaking vacum into the EVAP system.
GM WCT
PM Me for details
Old 12-12-2003, 07:05 AM
So basically take it to a shop cause I can't fix it?
Old 12-12-2003, 09:55 AM
GMMerlin's Avatar
I know stuff
Re: Re: Service Engine Soon ??
You will need to find someone with an EVAP tester and a bi-directional scan tool to do the proper diagnosis.
If you want to attempt a repair, you can remove and clean the vent valve...they are know for getting dirt packed in them and stopping up.
GM WCT
PM Me for details
Old 02-04-2004, 02:51 PM
justtim justtim is offline
ses light
can anyone tell me what p0410(secondary air injection system malfunction) is, and how to diagnose the problem
thanks
Old 02-05-2004, 08:17 AM
GMMerlin's Avatar
I know stuff
Re: ses light
thanks
Dude, you don't have to bring up a dead thread, you can start your own.
P0410 is a code for a fault in the Secondary Air Injection system.
What year and engine size is your vehicle?
Most times, this code is caused by the Air pump locking up (due to water intrusion) and blowing the maxi-fuse.
You can check the fuse by removing the battery and the fuse is located in a small electrical center between the battery and the inner fender well.
If the fuse is blown, you will need to replace the Air pump and extend the intake hose to an area above the PCM.
GM WCT
PM Me for details
Old 02-09-2004, 07:04 PM
Tfulmer Tfulmer is offline
Re: Re: ses light
I have a 2001 blazer and have a P0410 (SES). In December I had it in the shop and they replaced air pump and check values. Then I had an error code P0442 and they said the gas cap is loose. Any suggestions?
Thanks
Susan
Closed Thread
