Old 12-07-2003, 10:47 AM
michaelwesolowski michaelwesolowski is offline
Blows cold air & Heated Seats
2 Problems
1-Climate control blows cold air. One mechanic said that a wiring harness was hold some flap open, thought it was fixed, but it is not. Anyone able to confirm, or comment?
2-Heated Seats worked last season, but not now. The indicator lights light up, but no heat. Anyone able to comment?
Old 12-08-2003, 05:06 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Blows cold air & Heated Seats
I would bet that your heated seat have a bad heating element you can buy just the element for most cars now it is a lot cheaper than buying the whole seat cover.
On your temp problem is your coolant full? If it is than you might have a bad temp mode door actuator.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 02-16-2004, 06:39 AM
ladler ladler is offline
what is a temp mode door actuator? Have an 85 Electra Park Ave - blows cold air. flushed and filled. replaced thermostat, water pump, blew out the hoses and the heater core - where is this actuator?
Old 03-11-2005, 03:31 PM
edicted edicted is offline
My 98 will blow cold air after I've gotten on it.. driving at 65+ then I get off the interstate.. with the climate ctrl at 72 its cold at 82 its warm and 83/84 is hot as hell.
