Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 12-07-2003, 10:11 AM
MAXIINC MAXIINC is offline
Cool Litle Smoke On The Morning
Hello ,first Time Here , Trying To Learn The Ropes I Have A 1997 A4 1.8 Audi 69000 Miles . On The Morning When I Start The Car Its Smokes For A Minute Then Stops , A Local Mechanic Told Me I Must Be The Turbo Leaking Oil. Any Comment To Help Make A Dessicion Since The Turbo Is Very Expensive. Thank You In Advance. Joe Maxi
Old 12-26-2003, 02:36 PM
shifts shifts is offline
Joe,
It sounds like valve stem seals to me
When a car sits over night oil from the head can leak past worn stem seals and drip into the valve \cylinder this will cause smoke on start up from 5-15 seconds depending how severe it is.
It could also be rings or the turbo but I doubt it..... If its turbo seals it would not stop smoking
I'm a correct to assume that this is blue smoke and not white \ i.e.: hg
Dan
Old 12-28-2003, 02:54 PM
Re: Litle Smoke On The Morning
Thanks Dan I Think Your Opinion Is More Realistic That My Mechanic . I Will Ck. Into That .
Old 02-08-2004, 08:13 PM
1 PRODIGY 1 PRODIGY is offline
Send a message via AIM to 1 PRODIGY
i would suggest talkn to a audi tech instead of a common mech, and when cars are cold there well be a lil smoke naturally...
