Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-06-2003, 09:51 PM
fubufolks fubufolks is offline
94 Ranger Fuel pump doesn't always work
Sometimes, the fuel pump on my 94 Ranger (actually a Mazda B4000) doesn't come on. If I let it sit for 30 minutes, it will work. I replaced the fuel pump relay, and that worked for awhile. Another time when it wouldn't start, I pulled the relay and reinserted it; then it started. It only happens about once a month. Any suggestions? Can someone tell, externally, if my fuel pump is bad?
Old 12-06-2003, 10:00 PM
freezin-mybunz-off freezin-mybunz-off is offline
Re: 94 Ranger Fuel pump doesn't always work
is the relay hot when this happens?
Old 12-08-2003, 08:06 AM
jayscott jayscott is offline
Re: Re: 94 Ranger Fuel pump doesn't always work
Hi, know anything about 99 explorers? Have fuel supply prob.
Old 12-08-2003, 12:30 PM
Note sure how hot it was when this occured, but I do live in FL. It definitely happened this summer 3 or 4 times; not sure about winter.
Old 12-09-2003, 07:54 AM
was thinking that either there may be a short that is popping the relay or that something is wrong with the pump and it is drawing too many amps. as for the exploder, what is the prob?
Old 02-29-2004, 03:05 AM
ThawedAlaskan ThawedAlaskan is offline
Try checking groung connections. Had the same problem with my fs bronco and after 2 new pumps, a filter, and lines... just happed to bump fuel pump ground wires at battery while broken down and every thing sprung to life. $.10 ring connector fixed problem completely.
