Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-06-2003, 08:51 PM
davidparkwalker davidparkwalker is offline
Parts & Service? Grand Cherokee w/125K miles
Hi,
1995 Grand Cherokee Limited w/125K miles - no off-road usage
Generaly the car runs well.
In addition to the standard ingnition tuneup (cap, plugs, rotor, wires): I'm replacing the oxygen sensor, crank case breather/oil/fuel filters, sepentine belt, ignition coil, wiper blades, light bulbs & tail gate gas-charged lift supports.
Any suggestions what else should be replaced? Timing belt and tensioners? An auto mechanic is performing the work.
Thanks in advance for any assistance . .
Old 12-09-2003, 12:49 PM
snidelywhplsh snidelywhplsh is offline
Re: Parts & Service? Grand Cherokee w/125K miles
If you brought it to my dealership we would change in addition to what you have done : Lube oil filter,coolant flush,front axle service ( change lube ),transmission service ( NOT FLUSH ) with filter,transfer case service,and last rear axle service. check your manual or call the dealer to get the correct fluids ! Some models take special axle and t-case fluids.These items should make you good to go !
JEEPGOD
