Old 12-06-2003, 04:14 PM
AbsolutelyClueless AbsolutelyClueless is offline
Question '90 Civic SI hatchback Swap questions.
I have a 1990 Civic SI hatchback with 300k on the motor. time to retire it and either rebuild it, replace it or "upgrade" it. The cost delta between stock and 25 more ponies is too small to ignore. So...
I've read the faq, searched the forums, consulted the stars, and glanced at the tea leaves yet I still have a few questions.
The Faq list these direct bolt in performance engines:
D16A6 or SOHC ZC - 108hp, great upgrade from DX/LX engine. cheap.
JDM D15B - welcome to VTEC. nice peppy engine, 125-130hp
D16Z6 - quick, with bolt ons should be able to beat allot of other sport compacts, 125hp
D16y8 - same as D16Z6 but 127hp
DOHC ZC - quick, similar performance to SOHC VTEC but DOHC NON VTEC, aftermarket support not quite as great as SOHC VTEC, 130hp
Someone Define "Bolt in"?
If I get a D16Z6 or a ZC can I use my existing tranny? ECU? wiring harness?
Are all Z6's the same? if not which year should I get?
Which Clutch package? 90 civic si? or donor car?
I'll be doing the swap myself but want very little down time. I don't want to be running around looking for this hose, that plug, and god knows what else.
I want simple, quick, seemless and clean.
BTW, I'm not going to racing or even pretending to. This is a commuter, run around town car. When I want to get the polices attention, I'll take the Jag.
Old 12-06-2003, 04:56 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
If you just want the car for an around town car, I would just replace it with the stock motor, or look for a sohc zc since they have low miles. You can look for a newer motor too such as a d16y7. I would stick with a non vtec motor to keep the swap as simple as possible. Are you going to reuse your tranny? If you have any more questions feel free to ask and I hopew this helps you a little.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 12-06-2003, 05:00 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: '90 Civic SI hatchback Swap questions.
The term "bolt in" means that you dont need to spend $300 on new motor mounts, you can use your existing motor mounts. Which engine you choose (if you choose to replace it) is completely up to you. Personally, out of all those I would probably pick the D16Y8 because it will most likely have lower mileage than most of the rest, its a common engine so the aftermarket support is good, and its pretty peppy. All of those engines listed will bolt up to your tranny. For the ZC's (SOHC and DOHC) you can use your stock ecu, but the rest will require different ones. If you get the SOHC ZC, you can use your existing wiring harness and I think you dont even need to modify it. With the DOHC ZC you will need to add a couple wires but its pretty easy. When you get an engine with vtec, you will need to add a few more wires and find a way to activate vtec via an RPM activated switch, or an VAFC or something. The Z6's im pretty sure are all the same. As for the clutch, yes you will get one for a 90 Si if you stick with that tranny. I think that answers most of what you asked. If you have any more questions about a specific engine or just a general question, feel free to ask, theres a lot of knowledgeable people here that will be glad to help you out. And by the way, welcome to AF
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-08-2003, 12:08 PM
If I go with a newer motor, can I use my stock exhaust? Stock ECU?
How about If I go with a DOHC ZC, does the same apply?
If I put three "type R" stickers on it will it make it run any better?
Old 12-08-2003, 02:08 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
Re: Re: '90 Civic SI hatchback Swap questions.
you can use your stock ECU as long as you use your stock distributor and intake manifold.....if you use the distributor and intake manifold from the new engine you have to use that ECU.
I'm Jordan
My car is the ugliest one on this board
Old 12-08-2003, 07:58 PM
cot's Avatar
cot cot is offline
Depending on local smog laws, i think you may have to have all the smog equipment that came with the engine, so if its a newer engine id think you might need the new ecu to deal with the new smog stuff you may be adding
smoggability should be something to keep in mind
