Old 12-06-2003, 12:33 PM
DirtBike1128 DirtBike1128 is offline
Send a message via AIM to DirtBike1128
what is BOOST CREEP
my question is simple: what is boost creep?
Old 12-06-2003, 02:10 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
I am going to preach again. People need to Search. its not that hard and odds are you are not the first person with this problem/idea and its already been talked about.
But on a different note here is a brief explanation by 95GSXracer on what boost creep is. "I cant get the www.racingknowledge.org website to work here at work, but I believe there is a sticky about WGs and boost controllers that may also explain creep. The very short version is that its when your WG cant bypass enough exhaust around the turbine wheel to accurately control bost. The result is it will hold set boost until some rpm where it will start to rise on its own and continue doing so until you let off. As an example, my 14b with 2.5" BR turbo back (test pipe) would hold 18 psi to about 5500 rm, then it would rise to 22 psi by 7k. "
and if you want to know how to cure the problem you can start by porting out you o2 housing. check www.vfaq.com , you can also do a search because once again it has been discussed before. hope that helps.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 12-06-2003, 02:27 PM
Re: what is BOOST CREEP
it does...but just to let u know...i searched on a few sites, and yes i came up with a ton of topics concerning boost creep, but not one explained it. so, make sure u preach to the right people. thanks again.
Old 12-07-2003, 01:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
Cant blame him for asking poeple to search. There are questions that I answer every day. Its like going to work, or taking a shit. You just know you are going to have to do it. Boost control issues, trying to swap a 4g63 into a NT, etc. I have a folder with about 50 text files where I copy my long, frequent replies so I can cut and paste when it gets asked over and over again....
But in your defense, I know there is a TON of msinformation out there. Go to a forum and ask what boost creep is. If 20 people answer, one will have it right.
95_GSX did a good job giving the short version. I believe that sticky on RKO does explain it well. If you still have specific quesitons after reading it, let us know.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
