Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-06-2003, 12:32 PM
adalcanto adalcanto is offline
Where is the neutral safety switch?
I have a 98 grand cherokee. The reverse lights no longer work (it is not the bulbs). I have read that the neutral safety switch can get gunked up and that the circuit to the reverse lights goes through the switch. Removing and cleaning it should fix the problem... but where is the neutral safety switch located on the 98 gr. cherokee? Diagrams/pics would be very helpful. Thanks.
Old 12-21-2003, 06:22 AM
injunarts injunarts is offline
Re: Where is the neutral safety switch?
It is located on the passenger side of the transmission under the veh. There is one nut to get it off.
Old 02-26-2005, 10:30 AM
paulgreen paulgreen is offline
Send a message via MSN to paulgreen Send a message via Yahoo to paulgreen
Re: Re: Where is the neutral safety switch?
I've been under my car a couple of times looking for this.. I've got a '97 RHD Grand Cherokee.. coudl you tell me where to find the Neutral Safety Switch exactly? is it above/below, on the side, above or below the ridge of the transmission? Can it be seen or do you have to feel around for it?
Old 02-26-2005, 10:51 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
on the 42RE/42RH/46RH transmissions (I am sure it is the same for all other trannies too). The Park/Nuetral or Nuetral Safety Switch is located on the Passenger side of the transmission right above the OIL PAN the is a (I do believe) a 3 wire electrical connector.
Old 02-26-2005, 10:55 AM
Dale Aeppli Dale Aeppli is offline
Re: Re: Re: Where is the neutral safety switch?
CHECK OUT jeepin.com THEY HAVE A ARTICLE ON CLEANING THE NSS SWITCH HOPETHIS HELPS DALE
[email protected]
Old 02-26-2005, 11:20 AM
Thanks, Another silly question.. is it the bit above the oil pan under the hidden behind the exhaust piping and around all the spring parts for the gears (automotives aren't my thing.. hopefully, when I get it off it's easier to do the clean!!)
Old 02-26-2005, 04:29 PM
glass glass is offline
I have an intermittand reverse light problem as well, but , my neutral switch is brand new , upon a trans OH.....However ..when I took the 94 GC limited to the dealer for recall upgrades , they took the center consul apart to install the brake lock safty , and evidently didnt adjust the switch in the shift colum properly , and i have intermittant reverse lights , they come on and off jiggiling the shift lever
Old 02-27-2005, 04:59 AM
I'm off out to have another crack at this now.. wish me luck and thanks for all your help guys.
Old 03-21-2005, 08:35 PM
sbadia sbadia is offline
I'm having hte same kind of problem with my 1998 grand Cherokee limited. Please could you tell me if you were able to resolved your light problem.
Old 03-27-2005, 12:21 PM
lilmissjaclyn lilmissjaclyn is offline
I cleaned the NSS on my 93 Jeep GC for the reverse light problem, but it did not help, though the NSS was definitely gunked up.
Old 03-27-2005, 01:53 PM
http://www.autozone.com/servlet/UiBr...3d80154044.jsp CHECK THIS SITE DALE
[email protected]
Old 03-29-2005, 02:22 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I have the same problem on the 93 Grand Cherokee. I replaced the park neutral safety switch and it worked for a while and sure enough no reverse lights. I believe the rod on the left (driver's side) on the transmission can be adjusted for the switch. The rod goes through the transmission and through the park neutral safety switch. I haven't tried to adjust it yet, but if it works I will update
Old 04-06-2005, 01:42 PM
tech_ed tech_ed is offline
Here's a small series of photos I took of when I replace the NSS on my 89 and 90 cherokee:
http://newton.tek-ed.com/jeep/
Ed
web/gadget guru
Old 04-08-2005, 05:14 PM
nicispriceless nicispriceless is offline
Send a message via Yahoo to nicispriceless
I have a 98 5.9L and I had a problem with my speed sensor. I went out and thought i had bought the speed sensor and it was in fact the park/neutral switch. Both are located, and look the same, right were the transfer case and the tranny connect.
