Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 12-06-2003, 11:20 AM
scrylry scrylry is offline
1964 Corvette
I am working on a friends Vette rear bearings. It has rear drum brakes. I found on the spindle a non castleated nut with a cotter pin being used as a retainer but no real way to adjust bearing tension. Does anyone know if it should be a castle nut?
Thank You
Larry Ross
Old 12-06-2003, 06:10 PM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Re: 1964 Corvette
Larry dont know that one but if your like Texas Hotrod your going to die..LOL see his thread on 88 vette...
Anyway have you tried to look at year one? or Ecklers?
Old 12-06-2003, 06:24 PM
carguyinok's Avatar
carguyinok carguyinok is offline
Re: 1964 Corvette
I know it was a castle nut on my 73 vette. I think your best bet would be to pull the other side and have a look. If they match odds are there stock. If some one was to replace a castle nut with a reg style nut they wouldnt have dont bolth sides that way. I dont think you could do some thing that dumb and be smart enough to replace bolth rear wheel bearing sets the way you should.
Rules of the game fast,good, cheap pick any 2
fast + good = not cheap
fast +cheap = not good
good + cheap = not fast
Because the water has no speed limits
Old 12-06-2003, 06:29 PM
Vlad_Tepes's Avatar
Re: 1964 Corvette
http://www.madvet.com/shop?frame=5.3866
Larry check that out.. I got from Mid-America Corvette..
Hope this helps.
Old 12-26-2003, 03:32 PM
LATER LATER is offline
all of the 63-82 rear spindles had castle nuts on them, retained by a cotter pin. the adjustment for the bearing is not in how tight are loose you leave them, but is rather the shimming of the spacer between the outer and inner bearings inside the spindle housing. hope it helps
