Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 12-06-2003, 06:39 AM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
Ae86
(I also posted this in the toyota forum but im not getting any responses)
Their is an AE86 for sale down the street from me. I could not believe my eyes when I saw it. I could not stop at the time but from the out side it didnt look to bad for 15+ year old car. You know it needs paint and some minor body work but not to bad. Im going next weak to get details but I could care less if it runs or not. I want to do a total rebuild this would be my first but I have a friend who is a mechanic. Anyways I want to know the strengths and weaknesses of the AE86. Like does it have a weak transmission or what kind of potential does the motor have? A dont know much about the AE86 other than Initial D stuff So any info you guys could give me would be great.
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 12-06-2003, 06:48 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: Ae86
well first make sure its got the dohc engine and not the sohc one
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 12-06-2003, 07:06 AM
RACER D12's Avatar
It should say dotch right on the block right?
Old 12-06-2003, 07:11 AM
Neutrino's Avatar
Yaya Master
Re: Ae86
yeah...it should on the valve cover
plus the dohc heads are vay wider than the sohc
as a rule of thumb if the head narrows at the top is sohc and if its squarish its dohc
(\__/)
Old 12-06-2003, 07:44 AM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
Sohc would be a SR5 I think and to top that off it's carb'd .
Old 12-06-2003, 08:01 PM
RACER D12's Avatar
Can I get any more info?
Old 12-06-2003, 08:16 PM
2of9 2of9 is offline
it can drift on turns at 80+ MPH!!!hahahahaha.....
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-07-2003, 05:05 AM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
the AE86 you want is the GTS. Comes with the 4AGE motor. Doesn't make all that much power, so the 4AGZE motor from the supercharged Mr2's are a popular swap. The ae86 handles excellent, and has a near 50/50 weight balance if I'm not mistaken..
when in doubt, throttle.
Old 12-07-2003, 03:07 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
The AE86 is by no means a good pick if you want a really fast car... It's all about the handling. It's a very stable, lightweight car with very good handling characteristics.
The stock engine makes around 120hp, but can be tuned to around 150hp with bolt ons, porting, etc. After this point, you're looking at raising the compression and changing out the cams, so it's not really worth it. If you feel like swapping out the pistons, than turbocharging may be the route for you. You can get about 300hp from a turbocharged 4A-GE, although it gets pretty peaky at that level of output, and you lose most of your low end.
The 4A-GZE is just a 4A-GE with lower compression, and a supercharger. You can do the bolt ons, and overdrive the supercharger to get around 220hp, which is damned good power in a 2100lb car. If you want to spend a bit, get some nice 8:1 forged pistons, and a large trim T3, and run a twincharge setup like HKS did. Not all that expensive, and not all that hard really, and you wind up with a very streetable 300hp.
The trick with the Hachi is to exploit it's low weight, drop weight everywhere you can, and get big tires, and you'll have the recipe for an awesome sports car. Add more power, and you have a very competitive machine.
If you want a peppy car with great handling, you can't go wrong with the GTS. If you feel like putting more money into and getting more speed out of it, a SR5 with a 4A-GZE swap and brake/suspension upgrades will be good.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 12-07-2003, 04:06 PM
RACER D12's Avatar
Ok so it sounds like if I do buy this car I will want to do and engine swap, because I do also want a fast car. So what year MR2s would have the 4A-GZE? Will it be a hard motor to find? Also what other motor options are their? Could I do say a SR or KA swap?
Old 12-07-2003, 04:31 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
yea SR can be done hmm no linky to help though best bet is just 4a-ge with blower.
Old 12-07-2003, 04:40 PM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
Well, Nissan to Toyota swaps aren't particularly easy, and you'll have to get friendly with a welder and torch because it falls into the "Ain't no kit, sonny" territory.
Mister Twos that have the 4AGZE are the supercharged models produced in 1988 and 1989. They're fairly rare, and as such are prized by both MR2 owners and AE86 owners alike.
A better bet, if you want to go the factory supercharger route, might actually be to hunt down NOS parts (that's New Old Stock, for those of you who don't restore cars) and attach that to your 4AGE. A bandaid for the compression ratio (you'll have higher compression than a ZE, so you'll have a potential detonation problem) is to use a thicker head gasket (usually you can play with compression ratios by a few tenths by running a head gasket a few mm thinner or thicker than stock).
Naturally, though, eventually you'll want to tear into the engine and do it proper.
What i don't grasp, though, is why people instantly think an engine swap is the simplest route to more power. With the high level of computerization, even in cars a decade or even two decades old, you've got so much room for error and for failure it becomes a mess before you start. We're not talking about a carbed Chevy 350 with a magneto that can practically run on its own sans car, we're talking about swapping in not only an engine, but near the whole frickin' wiring harness. Computers, sensors, coil packs, all of that nonsense has to come out of the donor car and be spliced in with the stuff already in the recipient. It's complex, expensive, and incredibly time consuming.
You'll have a much easier time of it working on the 4AGE. I've had my hands in one of those engines in a MR2, and they respond well to a little intake/exhaust work and really come to life with a hotter pair of cams. If you take a bit of the slop out of the driveline and pull some weight out of the car, you'll have a real little terror in its class.
Trust me, swaps are for people with both experience and money. If you have neither, don't try it.
Proud Owner/Operator of Haven Raceway and Hobby!
Old 12-07-2003, 04:54 PM
RACER D12's Avatar
About how much would it cost then to turbo the 4A-GE? Also I thought the 4A-GE was a good motor with alot of potential? At least thats what I heard. Anyways how much hp would I need to make to run 13s?. Now before I get flamed I know the GTS is not about drag, but I want my GTS to be well rounded and with how light the car is I dont think 13s is that much to ask.
Old 12-08-2003, 12:21 PM
Supermodified
You heard right. The 4AGE is an excellent motor. But you're still only talking about a 1600cc four. You can pull a very streetable 150-185hp out of it naturally aspirated and that'd be enough to get either a MkI Mister Two or a HachiRoku really moving. Because the 'Rokus are light, RWD, and have an astonishing level of suspension grip (needs wider tires, though) they can do some amazing things.
My Dad, a GLH Omni driver, listed the GT-S Corollas amongst the cars he (and the three other GLH guys he hung out with) hated to line up against. While the GLH Omni had that great 2.2L Chryco SOHC torque monster and monstrous Goodyear Gatorback tires, the GT-S Corollas had top end revs like there was no tomorrow and RWD to keep things even off the launch.
Keep in mind, this was 1985-1992 when this was all going down. It wasn't until a little FF box from Nissan showed up on the scene that my Dad felt the GLH had finally been eclipsed.
13's may be pushing it on stock internals, but if you're going the turbocharging route you won't be using stock internals anyways. When you're bolting any sort of forced induction onto an engine, you're stressing the whole reciprocating assembly like nothing before. If you go that route, pull the engine and have it fully rebuilt with aftermarket pieces along the lines of a billet crank, forged rods and pistons, and go to better head studs like ARP's. Also, a secondary oil cooler and more powerful oil pump are a huge must to keep the engine and turbocharger lubricated thoroughly. You'll probably want to go to a larger aluminum radiator, and of course intercooling.
The potential for turbocharging is there, and the basics of it aren't difficult, but keep in mind that this is a higher mileage, near 20 year old car. You can't just go tossing parts at it willy-nilly without risking terminal failure.
Old 12-08-2003, 01:45 PM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
Re: Ae86
Huh? What car was this? No way!
2002_Nissan_Maxima_6-speed
