Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-05-2003, 02:06 PM
88zccivic 88zccivic is offline
o2 sensor location
this might be dumb question but i cant find any thing on it any were
if im using an hf manifold and a dsm turbo and o2 housing would it matter if i put my o2 sensor in the manifold or after the turbo
would one spot make an a/f ratio gauge more accuret than the oter
Old 12-08-2003, 06:07 AM
cuba3377's Avatar
cuba3377 cuba3377 is offline
Re: o2 sensor location
doesnt really matter. all the o2 sensor does, is measure temp. they way it does it , it woulnt make a big diffrence. i suggest though right after the turbo. somewhere around the bottom of the manifold. if u need to drill and tap for the o2 sensor, make sure u point it the right way,and also make sure its deep enough in the manifold
94 INTEGRA NEVER LOOKED SO GOOD ^^
Old 12-08-2003, 02:02 PM
ok thanks man
Old 12-08-2003, 05:47 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
The o2 does not measure temp. and even if it did then it would make a big difference where it was at. The manifold would be hotter than after the turbo. The o2 sensor measures the oxygen content in the gases and converts that to millivolts for the computer to read. the higher the millivolts the richer you are.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-10-2003, 11:33 PM
ok so for the best reading i should have it in the manifold befor the turbo?
Old 12-11-2003, 10:27 PM
Hypsi87's Avatar
Re: Re: o2 sensor location
Thats where it is on my car. From the factory
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
