Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-05-2003, 10:12 AM
pablos pablos is offline
Replacing the belt
There is a long accessory drive belt on the 4 cylinder. Its flat and about 1 to 1.5 inches wide with several ribs on the inside. The only name I can find for this is Accessory drive belt. Does it go by some other name. What needs to be done to replace it?
Old 12-06-2003, 09:36 PM
freezin-mybunz-off freezin-mybunz-off is offline
Re: Replacing the belt
i believe you are reffering to the serpentine belt. on the ranger that i have, there is a tension pulley under and just to the right of the alternator. there is a square hole on the front of the pulley that you can put a 1/4" drive ratchet in. rotate counter clock wise to let the tension off the belt. once the belt is slack you can easily remove it. a replacement can be purchased for under $15.00 at just about any parts store. when you go to put the new belt on, ive found it is easiest to put the belt around all pulleys except the alternator. then just rotate the tension pulley again and slip the belt on the alternator pulley. release the tension pulley and voila!
Replacing the Belt Tensioner rtobrian Grand AM 1 05-15-2010 11:22 AM
Replacing the belt idler pulley...I think 00RodeoLS Rodeo | Passport | MU 0 05-11-2006 02:24 AM
How do I replace the belt tensioner gradyn S-10 1 10-14-2004 09:10 PM
How to replace the belt tensioner idler/pulley on '89 Lesabre the_doctor LeSabre 1 09-28-2004 07:19 AM
How do you replace the drive belt in a 98? renojedi Sentra | 200SX (USDM FWD) 0 09-20-2004 10:12 PM
