Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-04-2003, 11:12 PM
bwrynn bwrynn is offline
Bonnevile Erratic Electrical System
My 98 Bonneville SE had new battery a month ago.
Now driving fine, but stop at a light then occaisonally engine stalls. Starts right away. Another symptom: Cd player also turned off & had to be turned on, the Cd now back to start of the disk. Indicates it lost memory of where it was.
Above happened to my son 3 times last saturday. Happened to me this morning once. While at idle both oil guage & voltmeter voltages declined and would wiggle. Leaving work engine wouldn't crank. I got out to get jumper cables from trunk as someone would help. Then heard the alarm faintly. Behind the wheel to pop the hood, lights suddenly became bright. I did not get the battery jump. Engine started on second try and I drove home.
In the driveway voltmeter showed 14.1 volts with car running. Turned off engine and battery showed 13.1 volts. Now 5 hours later it's 12.9 volts so seems like its not a drain. Any ideas?
Old 12-06-2003, 08:02 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Bonnevile Erratic Electrical System
Sure sounds like a either loose/dirty battery connections or a bad battery. Yes, there are NEW batteries that are bad. Especially those from Wally world or Autozone.
