Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-04-2003, 09:53 PM
slate slate is offline
Send a message via AIM to slate
V-AFC II worth it?
Before I start, I know I need a Hondata S200B for my fuel managment. But I don't have an extra grand or so right now for ECU's, harnesses, ect., sence I just had to rebuild the bottom end with Eagle H-beams and Wiseco 8.5:1 pistons. So in the mean time, I was thinking of trying the new Vers. 2 of the A'pexi V-AFC that I can get fairly cheap. I'm running a Rev Hard Stage 2 kit on my 2000 Si. I plan on running anywhere from 10-15 psi on high boost (around 5 psi daily). The only fuel managment I'm using right now is a Vortec FMU that came with the turbo kit. The kit also came with a larger intank fuel pump and I did add a Missing Link. The main reasons I want to try a V-AFC is to help smooth out the cars idle, because I'm adding some 450 DSM injectors, and to boost a little safer until I can get the Hondata.
So does anyone have any experience with a V-AFC II on a turbo set up?
If so,
1) whats the best way to use it. With/without FMU or with/without Missing Link, ect.
2) Will it help me any if I want to run boost levels of higher than 10 psi?
3) What problems have you come across?
Again, I know I need (and believe me I want) the Hondata unit, but its just not in the cards right now.
NO! I DIDN'T BUY THIS CAR AFTER SEEING THAT DAMN MOVIE!
Old 12-05-2003, 01:18 PM
CivicEXRider's Avatar
CivicEXRider CivicEXRider is offline
Go here http://pollito.no-ip.com/turbod16/viewtopic.php?t=2118 It'll explain how to use the VAFC with a turbo setup and larger injectors.
Old 12-06-2003, 01:13 PM
Thanks Rider. That was a lot of help.
Old 12-07-2003, 12:18 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: V-AFC II worth it?
sounds nice
