Old 12-04-2003, 07:40 PM
85cam 85cam is offline
85 iroc to a 12.5
I have a 85' iroc in good running condition it is completely stock. I want it to run a 12.5, so my question is what is the cheapesy way to get there while staying NA? Btw it is automatic. I want you guys to list everything from cams, to guages i am going to need, to better rear end, traction bars, tires i mean everything. I am willing to get it bored out if I have to. Also I wanted to stay under $2900 ....is this possible??? PS sorry for being a newbie I really dont know about these cars that much yet i used to own a talon tsi AWD.
Old 12-05-2003, 03:30 AM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Re: 85 iroc to a 12.5
Holy Shit batman you dont want much do you
Old 12-05-2003, 02:14 PM
Re: Re: 85 iroc to a 12.5
LOL haha yeah i guess i kind of do but I really dont know much. ANyway ills tart the list and if you guys think I need to add anything just say so.
cam
torque converter
slicks with rims
headers
3 in. duals with mufflers
bigger carb
traction bars?
would I need to bored out to a 355?
Would I need to port the heads?
here is what a friend has who the same car said he has and it will get him toa 12.5 is this true???
355 4 bolt......needs machine work (bore)..unsure of price for that.
Edelbrock Performer RPM intake.................................$114.95
750cfm Performer carb.............................................. $239.95
Edelbrock Performer RPM camshaft ............................$179.95
2.02/1.60 64cc Chevy heads, ported and polished:
2.02 exhuast valve...................set of eight................$71.50
1.60 exhuast valve...................set of eight................$71.50
10:1 Flat top pistons.........not sure what brand his are, but here are some Sterling Hypereutectic Pistons for a .020 bored over block.........$9.39 a peice $75.12 a set of 8.
3.42 rear gears.......................................stock
flowtech headers........................................... ......................$89.95
flowtech afterburner mufflers.......................................... ......$39.95
(thats what i wish i would of chose instead of flowmasters.
muffler shop to instal all parts on dual 3 inch pipes ~..............$100
summit mechanical fuel pump.............................................. $49.95
fuel pressure regulator......................................... ................$39.95
3500rpm stall convertor (th350)........................................... .$279.95
traction bars.............................................. .........................$65.95
subr-frame connectors (homemade)......................................$2 0
Old 12-06-2003, 03:06 AM
Vlad_Tepes's Avatar
Looks to me you have it all down but I'd go with a 2500 stall
Old 12-06-2003, 09:45 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
well batman, i would say you have a pretty good handle on what your lookin at, but what heads are you talkin about when you say chevy 2.02/1.60 64cc heads? that can mean alot of them. my suggestion, use vortech heads if you can, they are comparitively cheapper than dirt, and flow as well as some bowtie heads, especially with the 2.02 1.60 valves. you have to get an intake with the right bolt pattern, but aside from that, they bolt right on. i think a set of new vortecs are around 450 bucks now for both. and also, rather than doing all the expencive machine work to alter the heads for more lift, i reccomend this, use comp cams beehive springs, i forget thepart numbers right now, but they allow up to a .525 lift with no mods to the heads. and offer a progressive lift which is easyer on valve train components. and if you are looking to go 12's, i would run an even looser converter, and a ratchet shifter on that auto. also, a corvette 1st / 2nd servo, and a B&M transkit. with high performance clutch pads and built in shift kit. 700's tend to be rather slushy and will probly be your biggest obsical to running low ET's. so i would definately not forget to do something to your trans. alot of power is great, but if your trans cant put it down, you might as well have a four banger
