Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 12-04-2003, 02:29 PM
imaqh imaqh is offline
Send a message via AIM to imaqh
dead fiero
i have an 86 V6 SE fiero.It turns over but won't start.i had it running and then it just quit.I replaced the battery, fuel filter, ignition coil, pickup coil, rotor and cap, pretty much all of the emission sensors.The only thing I can think of right now is the ecu. I was wondering if anybody has had the same problem or if anyone has any suggestions.I have never worked on a fiero before so I'm sort of just guessing at whats wrong at this point. Thanks for any info. Annie Crowe
Old 12-05-2003, 11:11 PM
coop8267's Avatar
coop8267 coop8267 is offline
Re: dead fiero
hey imagh you might have bad injectors.
Old 12-18-2003, 08:45 AM
Jepster Jepster is offline
You might want to check out the fuel pump. The 86 V6 tends to lose pressure with age.
Old 01-07-2004, 11:34 PM
thecommi thecommi is offline
Send a message via AIM to thecommi
did you check the ignition module? under the cap/rotor, little black module, does it have a yellow dot on it? if yes then chances are its bad.
Old 01-08-2004, 02:40 AM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
have you checked the starter? A lot of the time a starter can crank, but not with enough torque to get it going. The 3rd gen maximas had a cronic problem that was due from the alternator going bad making the starter weak over time.
Old 01-27-2004, 06:12 PM
hillbilly_fiero hillbilly_fiero is offline
Re: dead fiero
mine has the same problem 86 se ran fine then quit now it wont start did the diagnostic test and got code 42. posted a thread about this to get some info as to what the problem is. if you get any info let me know
code 42 is the electronic spark timing
