Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-04-2003, 02:02 PM
1979C10 1979C10 is offline
Send a message via AIM to 1979C10
Oil leaks on 3.0L
I've worked at an auto repair shop for a number of years and had more than one maxima three liter come in for a mysterious oil leak. I spent a number of hours diagnosing the first one and found the leak to be coming from the bottom of the left bank. After teardown, I found there to be a small silicon rubber o-ring to be the problem. It was located at the seal between the block and rear timing chain housing, on the left. There is only this little 3 cent o ring standing between 60 psi of oil pressure and the outside of the motor. Is this a known problem? Is there a kit for a more permanent fix?
Old 12-04-2003, 02:56 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Oil leaks on 3.0L
i've never heard of it being a real problem. usually nissans are good about keeping oil. a lot of my friends with V-tec cars(which burns oil) are always amazed that i don't have to add oil nearly as often as they do.
as for a fix it kit, there aren't any i know of, cuz i never had the problewm and it's not really widespread. the best thing to do would be to call nissan tell them you're a mechanic and basically say exactly what you told us.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
