Old 12-04-2003, 12:47 AM
Mr.Sneaks's Avatar
Mr.Sneaks Mr.Sneaks is offline
SOHC D16A6 Cam Shaft
Just got my 89 crx HF with low miles and was thinking of throwing a cam in. I bought a hf shell and dropped in the si motor and trans D16A6(motor was free).
pt#270-251-0012
Crane Cams has a nice grind, anyone have any experience with this cam?
Adv.Duration- 261°Int/263°Exh
Duration @ .050''- 206°Int/208°Exh
Gross Lift- .394''Int/.386''Exh
Lobe Separation- 108°
All I have for the car is a cold air intake, header, and cat-back. Any suggestions would be appreciated.
Was thinking if I got the cam, I would buy a ported intake manifold, skunk2 or obx. oh and some cam gears
Old 12-04-2003, 02:16 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: SOHC D16A6 Cam Shaft
Cant...pass...it....up how many cam gears on a SOHC?
Old 12-04-2003, 10:42 PM
Mr.Sneaks's Avatar
Re: Re: SOHC D16A6 Cam Shaft
Thanks man,"Cant...pass...it....up" that's the same thing I said to your ugly girlfriend when I blew in her ass!!!!!
snoogens
Old 12-04-2003, 10:45 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I like the SR909 from exospeed, for that they suggest a ported head and manifolds, you can use stock valvesprings with the stock limiter, but with valve springs you can raise the limiter and use it to the full potential.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 12-04-2003, 11:47 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
If she is soooooo ugly then what were you doing? Maybe you pictured her as a guy explaining the blowing in the ass! 1 Hint of advice for AF is watch what you say to who or there will be a noobie flaming fest.
Check out my car here My 91 Hatch
Old 12-04-2003, 11:52 PM
91civicDXdude's Avatar
I would go with the deltacams 272 grind. has a nice hardcore lope at idle, and only costs $80 for the regrind.
Old 12-05-2003, 12:46 AM
Registered User
That was a good one kinda like the ones I used in 5th grade. Anyways I have a gude cam in my car (very agressive) and you need to get a adj. cam gear. If not then you will never touch my fat ugly ol lady again.
Old 12-05-2003, 10:02 PM
Mr.Sneaks's Avatar
No, just kidding it's cool man thanks for the responses, yeah I'd defintely get a adjustable cam "gear". Who else has a cam for the D16A6? All i can find is one at www.jegs.com and they have a very limited sport compact part of the site.
Old 12-06-2003, 12:56 AM
Registered User
Contact gude I have their cam (its a bit pricey) but its the most agressive one that I have ever drove...
Old 12-08-2003, 12:19 AM
Mr.Sneaks's Avatar
PART NO.:
HCCS07
DESCRIPTION:
Awsome power! A real plus with Bullfrog 2624 ECU.
POWER BAND:
4000 R.P.M. to 8200 R.P.M.
IDLE:
(Good)
SPECIFICATIONS:
Intake
LIFT -
0.415
DURATION -
241
Exhaust
LIFT -
0.421
DURATION -
228
Is this the cam, and how much did you drop on it?
Cheat On Your Girlfriend Not Your Diet!!!!
Old 12-08-2003, 01:07 AM
Registered User
Yea I dont rember exactly I got it in a deal but its shouldnt be more than $70 more than the other cams you find. E-mail them and ask. Hit the contact us button and tell them what you have and what you want. They will instruct you there.
how to switch out a cam shaft or a cam gear o0Quicksilver0o '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 01-22-2004 11:00 AM
D16A6 Cam and head question Tanked '88 - '91 Civic | CRX | Wagon | Shuttlee 8 07-16-2003 11:42 PM
cam shaft and cam gears in b16a GENONCARL Engineering/ Technical 1 03-28-2003 11:36 AM
Cam Shaft? GoldP11 Engine 6 12-29-2001 10:50 AM
Cam shaft fun! G-Forces Engine 2 08-25-2001 06:11 PM
