Old 12-03-2003, 08:56 PM
David_ David_ is offline
glue
hey, (sorry for all the new threads)
i saw ur glue tutorial, and i just wanted to say i have the revell glue, blue bottle, thin needle coming out the top, the dude said it was welding glue, or plastic glue, and it doesn't fog up windows (fogged up a lil bit)
i was wondering if this glue should be used for window parts, and if i should spread along the whole perimiter, or just use dot dot dot dot method? (8 dots in all aprox)
anyway, waht type of glue is this? cement, super, or crystal clear?
Old 12-04-2003, 12:23 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I don't use solvent cement or super glue (ca) on windows at all.
I use plain old 'elmers' white glue if the windows fit well and only need to stay in place or '5 minute' epoxy glue if they need a little encouragement to fit.
SCCA 7, The lost Z
Old 12-04-2003, 05:26 AM
RallyRaider's Avatar
Zomby Woof
What glue tutorial?
If it is plastic 'welding' glue then keep it away from clear parts. Other than that, experiment and find out what works for you. Don't any of you young folks do that anymore?
Old 12-04-2003, 08:35 AM
Re: glue
hmm... they said that it was ok for windows, i guessed they lied... what product should i use for windows? (any around the home that'll work? hobby glue, clear gum? etc?)
Old 12-04-2003, 08:38 AM
freakray freakray is offline
AF Modelrater
Re: Re: glue
You could use white glue for windows as long as it is the type that dries clear.
Old 12-04-2003, 11:01 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
theres a special glue for lcear parts called Krystal Klear
Old 12-04-2003, 11:33 AM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I use epoxy almost always. I don't handle my models a lot but every once in a while, a window held by white glue will pop out in my experience. Epoxy dries clear, pretty much, but if you get one of the two parts on the glass alone, it will smudge and be kind of hard to clean. I only use a tiny bead run around the edge, though, so the epoxy won't show up. The kind I use is thick, and doesn't squeeze out of tight spots when I use just a tiny bit. It can also fill some gaps, like around the windows of Revell's 510.
Old 12-04-2003, 03:55 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: glue
i use testors orange tube glue for the windows (and everything else..)
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-04-2003, 10:21 PM
600sel's Avatar
600sel 600sel is offline
Re: glue
David,
Do NOT use this for clear parts. Revell Contacta Special is for clear parts.
Old 12-05-2003, 03:34 AM
Re: glue
those hobby store ppl lied to me.... they said "don't use super glue, itll fog up ur glass" i said, "what wont" they gave me the revel glue....
i think ill just use bluetak for now, as i have no idea what products you guys just told me about, but thanks for correcting the welding glue probs, ta
Old 12-05-2003, 01:16 PM
ae86_takumi ae86_takumi is offline
Epoxy works best for me on clear parts
Current Project/Last Completed
Old 12-05-2003, 06:11 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Re: Re: glue
I doubt bluetak will help any cos it very likely going to be seen on the model. You mentioned you have no idea about the products the guys here mentioned - just pop into a art/craft store and get some white glue - ask the store assistant - its that simple!!
Old 12-06-2003, 04:45 AM
Re: glue
white glue... can i use pva? (wood glue)
glue problems Wolf95 Car Modeling 4 02-26-2010 10:47 AM
How to remove glue? Prelude2War Car Modeling 5 07-10-2004 12:57 AM
What glue to use when glueing plastic parts to painted shells? Sebstar Car Modeling 7 12-23-2003 10:11 AM
How long before the glue is set? kris Car Modeling 5 12-07-2001 07:59 AM
Glue 101 Jay! Car Modeling 8 09-29-2001 09:47 PM
