Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-03-2003, 07:42 PM
pbizzlegsr pbizzlegsr is offline
dyno tuning question
i currently have a 99 gsr with i/h/e..i have ctr cams that will soon be installed along with aem cam gears..i read everywhere that i should get my car dyno tuned to get max performance..the thing is can i just bring my car to a shop to get it dyno tuned with that setup or do i need some sort of vtec controller like an apexi vafc to use to tune?..im new to tuning so it might be an obvious question..anu recommended places around the bay? besides dsr? thanks
Old 12-04-2003, 12:34 AM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
go get it tuned at a tune shop.
Old 12-05-2003, 02:13 PM
BuyImports BuyImports is offline
Re: dyno tuning question
what do cam gears do?
Old 12-05-2003, 02:32 PM
XixGenuinexiX XixGenuinexiX is offline
although i don't know, @BuyImports try not to steal other people's thread
Old 12-05-2003, 02:37 PM
look, i'm new at this whole thing, i don't know how to steal a thread, i don't know what the point of stealing a thread is. I'm sorry if i stole a thread, i'm only on here to try to learn about cars
Old 12-05-2003, 04:16 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
Its ok to "steal" a thread, but dont mmake a habit of it, Im sure everyone in here has done it. Anyways, now instead of responding to the original thread starters question, Im going to write to yours. Cam gears(adjustable... stay away from DCs) allow you to adjust the timing of the camshafts. You can retard the exhaust and advance the intake allowing them to be open for longer periods of time. It all depends on your setup.
Old 12-05-2003, 05:22 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Adjustable cam gears also let you set valve overlap too
For the oringinal question yes you will need a Vafc or hondata etc to get the most out of it. But they can also just tune fuel pressure and cam timming to get it better than it would be if you were to just drop in the new cams.
Old 12-05-2003, 10:37 PM
well, now i know what stealing a thread is and i apologize, i didn't mean to do it, i won't again. also, thanks for the info on cam gears
Old 12-12-2003, 12:17 AM
cuba3377's Avatar
cuba3377 cuba3377 is offline
the more modifiactions that have vairiables, like a/f controls, fmu, the more adjustability, which means the more power u get from tuning
94 INTEGRA NEVER LOOKED SO GOOD ^^
Old 12-12-2003, 12:34 AM
91LSspecial 91LSspecial is offline
i have heard that wiht cams you should really really think about getting some valve springs that strictly match the cams you have, the new cams could really damage your stock valve springs, also an upgraded ECU is definatly neccisary, whether it be a jun chip or a APEX fuel mangement thingy...i really like the fields v-tec controller. i would take it to a shop have them put it in and set up the fuel managment system for you, it is very tech, and good shops really know how to set it up for you wether it be for strickt race or street relability
Old 12-12-2003, 12:38 AM
cuba3377's Avatar
best valve springs are titanium. they retail about 250. stronger springs= faster valve lift.
faster valve lift = higer rpm you can take your engine
Old 12-12-2003, 12:50 PM
Spectre927's Avatar
Yeah, if you dont get valve springs and retainers and all that crap, a lot more can me damaged than just your valve train if you raise the redline at all, and maybe even if you dont, some of them have pretty high lift.
Old 12-12-2003, 01:52 PM
whtteg's Avatar
Re: Re: dyno tuning question
You are a little off here stronger springs give a faster Vlave return or seat. The cam gives the extra lift and speed of the lift. The purpose of the stronger springs is to keep the valve from "floating" due to spring bind. The stock spring can bind in a high rpm/ high lift situation and casue the valve to stay opened and then the piston comes into contact with it and new motor or rebuild.
Yes you have to get the right spring for the cam other wise you can cause dammage to the Vlaves, Vlave seats, and the Cams. You can break cams from too large of a seat pressure ansd also you can wear the lobes really fast with too high seat pressure. Also you can cause Vavle mushrooming from the Valve spring seat pressure being too high, it causes the Valve to return to the seated position too fast and creates a mushroom effect on the vavle.
Old 12-12-2003, 06:05 PM
got v-tec?'s Avatar
all cam gears are for differant hp applications i got str camgears for 200 to 250hp just make sure what ever cams you go with they have 5 bolts or more.
Old 12-13-2003, 12:09 AM
Spectre927's Avatar
hum. Never heard that one...
