Old 12-03-2003, 05:58 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
turn signal seizure
Usually my turn signals are fine. But sometimes, they start blinking RAPIDLY and i mean RAPIDLY like 10 times a second. I looks and sounds like it is having a seizure. Does anyone else have this problem, or anyone know of a fix? Thanks.
For Sale 98 Eclipse GS, 5 spd
Old 12-03-2003, 06:58 PM
sramoon sramoon is offline
Send a message via Yahoo to sramoon
Is this problem in both directions (left , right). Maybe one your bulbs is burnt out or going out..i know if a bulb is out it takes less power to work the signal and it blinks faster like if you were to install leds. Check to see if you have all bulbs working when it does this rapid blinking.
Old 12-04-2003, 01:31 AM
kjewer1 kjewer1 is offline
AF - Advisor
Thats correct. You have a light out most likely. If it happens sometimes then goes away, it may be a bad connection somewhere. You have to wait until its blinking fast again, then take a walk around the car for lights not working. When you find the one causing the rapid blinking, play around with its wiring. In my case its a rear light, next to the right break light. It always decides to screw up when I'm trying to get my inspection sticker too...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-04-2003, 02:55 PM
ashah000's Avatar
Thanks. I will do that the next time it starts rapidly blinking
