Old 12-03-2003, 12:43 PM
VicVanDamne VicVanDamne is offline
Post Engine Problem
Hey Guys,
I have acquired a non-operational 1996 Eclipse RS from my brother and I am hoping with the advice of you good people, I can have it up and running soon.
So, as he tells me, two years ago, the car used to run but would use a lot of engine oil. He had to put in oil every 2 weeks. One day, the engine just seized, he suspects he had ignored the sign to put in more oil.
I suspect it may require a new engine. Also, what else in addition to the engine and tires (as has been sitting for two years) may need replacement?
Please do share your thoughts.
Cheers
Vic
Old 12-03-2003, 12:45 PM
CODE4 CODE4 is offline
Send a message via ICQ to CODE4 Send a message via AIM to CODE4
Re: Engine Problem
the struts are probably not in good condition if it has been sitting for that long. Otherwise drain all fluids and replace (clutch/brake/power sterring). Check the CV boots for cracking as those will need to be replaces as well.
______________________________________________
1999 Eclipse RS
ET: 16.1 @86.241 | Speedworld Motorplex, Phoenix, AZ
Old 12-03-2003, 11:52 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Engine Problem
save up and swap the whole engine for a turbo'd 4g63 and save yourself the headache. everything else will come in time..
Old 12-04-2003, 12:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
Cant put a turbo 4g63 in a 2g NT unless you plan to make all of the motor and tranny mounts yourself. Unless you are a master fabricator, dont bother.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-04-2003, 12:17 AM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Re: Engine Problem
even if you are, don't bother
Old 12-04-2003, 08:02 AM
Re: Engine Problem
Hey Guys
Thanks a bunch for your inputs. Do you know any sites that sell mitsubishi engines. The specs are non-turbo, 16 valve, 2.0 DoHC.
Cheers
Vic
1998 Chevy Lumina Engine Problems? Engine Swap to 3.8 jonfit04 Lumina 12 11-10-2010 08:15 PM
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
engine problems. always engine problems. alwaysproblems Fiero 2 04-09-2007 01:56 PM
b16a problem on crx, engine problem crxsirpr Let's get Technical! 0 03-02-2004 02:25 PM
