Old 12-03-2003, 12:54 AM
seraphin5000 seraphin5000 is offline
gutting the cats???
I drive a 93' base. I really want to open up the exhaust for as little cash as possible. Seeing as I have none, and that's the reason I got a base for 5g instead of a VR-4 I need cheap ways to improve the performance (for now...). I was wondering how I would go about gutting the precats and/or the cat. And I would like to know if this would be diffucult or relatively easy. Thanks
Old 12-03-2003, 12:43 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Are there pre-cats on a NA 3000GT? I thought those were there on the turbo models only.
In any case, take the cat off, and use some tin snips and cut out as much of the honeycombed metal as you can. You can stand it on end and use a soft steel rod (copper) and hammer to punch out as much of the rest as you can.
Put it back on and it'll look like a normal cat, but it will not pass emissions testing if you have it in your state.
Resistance Is Futile (If < 1ohm)
Old 12-04-2003, 02:31 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Doesnt removing the cat on an N/A reduce the backpresure too much? I would think you would lose torque. Please correct me if im wrong.
Old 12-04-2003, 10:52 AM
YogsVR4's Avatar
You’re right, torque is sacrificed for the HP gains. So launching will be a bit slower, but the top end can be a bit higher.
