Old 12-02-2003, 11:15 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
installing a radiator
any tips? i saw in my chilton's that i hae to remove the radiator from hte bottom of hte car, is this true? i would think it would be easier to take it out from up top. so any help with that and stuff to look out for, all would be greatly appreciated.
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 12-02-2003, 11:24 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: installing a radiator
You should just have to undo the hoses and drain it and the regular stuff, then there are 2 brackets one on each end. Unbolt these and the radiator should pull out. Oh yeah and undo the fan.
Check out my car here My 91 Hatch
Old 12-02-2003, 11:49 PM
BullShifter's Avatar
Re: Re: installing a radiator
I think it's easier to pull from the top. Does your car have A/C?
Remove the radiator cap & disconnect over-flow hose
Remove splash gaurd to expose petcock(radiator drain)
Drain radiator & coolant over flow
Disconnect cooling fan connection
Disconnect upper-rad. hose
Remove rad. support bolts
Lift rad. straight up
Disconnect lower rad. hose
Transfer fan to new rad.
Reverse for install
Fill coolant with engine off - add as much as you can
Start engine & add more coolant
Cap of the rad. let warm-up & then bleed air
re-check level when the car is cool - add if needed
I check when they're hot, be careful if removing the rad. cap while HOT. Thats why I said "when the car is cool.
Its a good time to replace the hoses if needed.
When re-filling use 50/50 mix water & anti-freeze
For detailed information check -----> http://www.binghamtonlife.com/manual/2gsm/cooling.htm
Old 12-03-2003, 01:08 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
it should take u no more than five min to take it out
Old 12-03-2003, 01:46 PM
havnfun328 havnfun328 is offline
Do it from the top.
Hardest part is getting the hoses off. Cut them and use new. They're probably old anyway.
Old 12-03-2003, 02:54 PM
Jay eS Iye's Avatar
i likehte way that sounds, so i'm hoping i can get this done in less than an hour then, seeing as i have to take a 40 minute drive tomorrow afternoon, blah
and yes i have A/C
Old 12-03-2003, 04:03 PM
gsf1200m gsf1200m is offline
It should probably take less than an hour if you dont run into any problems. I had a/c in my car and didnt run into any problems.
Old 12-03-2003, 11:19 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I did min in 30 minutes, but I had lots of motivation!
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 12-04-2003, 03:10 AM
It takes 5min. just to drain the coolant
Old 12-04-2003, 03:11 AM
H4Bangin's Avatar
i have AC also... thats no big deal, i had a hole in my radiator a few weeks ago the guy at the radiator shop told me to go home and pull it out then bring it in then he would fix it, i said nah ill pull it out real quick here, lol i had that thing out in two min. he was like damn u should work for me,
its so easy all u need is a 10 mm socket/ratchet, and a pair of pliars for the radiator hose
pop the 2 top brakets off, undo the 4 bolts holding the fans on, disconnect the top hose ( i didnt drain mine i just disconnected the hoses and let it flow out) disconnect the fan plugs, pull the fans out disconnect the bottom hose an the overflow hose and pull that summamabitch out
Old 12-04-2003, 07:14 PM
Jay eS Iye's Avatar
man the radiator itself took no time at all. only problem was that teh main fan doesn't bolt up right, the holes in the radiator don't match up.
the thing that took time tho was the bottom hose connection. for some reason it wasn't sealing, so i had to keep adjusting it. but i finally got it and the car runs nice and cool now
Old 07-25-2005, 09:14 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
If I switch to an all alluminum KOYO rad. will i need to replace the thermostat, or should i do that anyway. And if so then should i get a different heat range or keep it the same.
Old 07-25-2005, 09:20 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
No, and dont bring up threads that are two years old.
Old 07-25-2005, 10:29 AM
91CRXTC's Avatar
So was i supposed to run a new thread to ask that question. and if so then why have it there.
Old 07-25-2005, 03:59 PM
Forunn Daberator
Direct quote from the rules thread
2) Do not bring dead threads (Old Threads) back from the dead. Using them as a source of research is fine. However, check the thread dates before you post and do not post in dead threads. Dead threads brought back to life will be locked. If you have a problem or question relating to the thread, start your own thread instead of posting in the dead one.
