Old 12-02-2003, 07:22 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
help for LS swap
ok im getting a great deal on a LS swap. all i will need is a alternator,and to replace the piston rings cause it is smoking a lil, i will probally go ahead and do pistons, rings, and rods. and i'll see about a P&P on the head. im putting this into a 90hb, what else could i replace in the motor to make sure it is running 100% i even am considering going with a b16 head to have vtec... what are pros and cons of that, any help would be great.
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 12-02-2003, 10:35 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Goa head and replace the water and oil pumps and anything else that would require you to tear the engine apart again...timing belt and seals. As for the ls/vtec I have no idea I am still A6ing
Old 12-02-2003, 10:39 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
Re: help for LS swap
im going through this same swap right now. i changed the timing belt, water pump, thermostat, oil pan gasket, head gasket, spark plugs, but if i were you i would wait to put the b16 head on. its alot of work to build a good ls/vtec engine. http://www.importreview.com/reviews/lsvtec.html
check this site out. i think if you wanted to a little more hp then maybe you should buy some decent cams before you jump into the ls/vtec setup.
As American As A Burrito!
USDM 4 life!
Old 12-03-2003, 11:51 AM
black89crxLs's Avatar
black89crxLs black89crxLs is offline
Send a message via AIM to black89crxLs Send a message via Yahoo to black89crxLs
good idea, u have to re do dowel holes, get a new water and oil punp, b16a head, flows good, install oil squirters, run slightly thicker oil, to keep parts good and coated, be expecting about 160-185 in HP, and the Tq is ungodly,
Old 12-03-2003, 12:11 PM
outofstep's Avatar
lol, sounds pretty hard and expensive to LSvtec...
i wonder how fast just a built up LS would be?
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 12-03-2003, 01:00 PM
Re: Re: help for LS swap
instead of building up an ls you could always piece together a turbo setup that would be close to the same price as building an ls. and would have a decent amount of power, ls turbo setups are usually at least 200 whp.
USDM 4 life!
Old 12-03-2003, 01:47 PM
STOCK LS IN A CRX, WILL RUN ABOUT HIGH 13 TO A MID 14....ALOT TO DO IF THE DRIVER CAN HOOK IT UP AND FEATHER IT OUT TO CATCH TRACTION!!!!!!!!!!!!!!!!!!
Old 12-03-2003, 09:06 PM
slo89 slo89 is offline
Send a message via AIM to slo89
i have a stock '91 ls engine with 120K miles on it in a 89 4dr, all i have is a act 4-puck clutch disc and a chipped ls ecu w/8000 redline and it will pull on second gen. b16's. build the ls and beat them all.
Old 12-03-2003, 09:37 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Re: Re: Re: help for LS swap
not a chance....
from a stock b18 you can expect very high 14's to low 15's. zc in a civic runs 14.9-15.0 with the si trans...ls trans has wider gearing, so i doubt that its faster than a zc on a 1/4 mile run. both have about 140 hp.
any route you go...your options will be limitless witha b series motor...each route has its pro's and con's, but you can make power many different ways. its really a matter of personal preference.
if you wanna do something really cool that not many people consider....look into the stroker kits that eagle has for the b18. I think after the new crank and internals, your displacement is something like 2.3 liters.
crx + 2.3 liters of non-vtec fury = yumm
There's nary an animal alive that can outrun a greased Scotsman!
Old 12-03-2003, 10:59 PM
my91crxsi my91crxsi is offline
im also doing an ls swap into a 91 crx si
and need info on the wiring, the b18a1 is from a "93 so its obd1 im wondering if i can trade for a 90-91 ecu, use the modified crx harness and get everything to run right any info would be helpful
Need Help For Engine Swap! truckndude C/K 2 10-06-2005 06:54 PM
engine swap help for a newbee chucks88firebird Camaro Discussions 6 12-02-2004 09:54 PM
Engine Swap help for a 91 colt JZambrano1983 General Discussion 2 11-01-2004 01:42 PM
Need help finding good engine for swap! plz help! B18Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 07-13-2003 08:24 PM
Need help for swap. Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-20-2003 04:01 PM
