Old 12-02-2003, 07:16 PM
David_ David_ is offline
stripping paint
i was wondering, if i got a paintjob horibly wrong, what "safe" method can i use to remove all the paint from it? (including paint within the crevices)
i know sanding works, but not for crevices, i was thinking some type of fluid, eg: bleach, turps, metho, etc...
can anybody give me advice? thanks a bunch
(also, if u could, advice on how to two tone a car, without losing too much detail, and how to mask properly "guna do an id 86")
Old 12-02-2003, 07:31 PM
ImportBuilder's Avatar
ImportBuilder ImportBuilder is offline
Send a message via AIM to ImportBuilder Send a message via Yahoo to ImportBuilder
Re: stripping paint
CSC, Castrol Super Clean, my freind! u can get it Auto stores almost ne where. Also, brake fulid works. but, i used brake fluid 2 strip an old body, n it now has pits in it, yet on the other hand i have stripped other bodies w/o ne problems, so if ur usin brake fluid, i dunno how "safe" it is 4 plastics. *whatever u use 2 strip ur paint, ALWAYA wear gloves. THICK gloves* rubber kitchen gloves aughta do it.
Now Playing:
1x Pioneer DEH-3800MP HU
2x Majestic MCS650BC
2x Majestic MCS6923BC
4 AWG Power/Ground
1x Lightning Audio STRIKE S4.15.VC2
1x Lightning Audio STRIKE 24.500.1
Dynamat Xtreme in trunk
Coming Soon:
New SPL Setup
Old 12-02-2003, 07:36 PM
freakray freakray is offline
AF Modelrater
Re: stripping paint
Welcome to AF David.
Please read the Car Modelling FAQ, paint stripping is one of the subjects covered in the FAQ.
Re: stripping paint
pits in ur body? what is that... and how do i do it? just pour over model, or i gota leave it in the fluid for a week or so?
and can i use that fluid again? to clean other models?
Old 12-03-2003, 04:32 AM
cyclone1410's Avatar
cyclone1410 cyclone1410 is offline
Honda Convert
Re: Re: stripping paint
Yes unfortunately different plastics (even from the same kit) react slightly differently with brake fluid. I have had bumpers and spoilers strip fine and the actual body become slightly pitted after being imersed in brake fluid yet on other occassions it is the reverse.
Anyway to answer your other questions, you generally have to leave it imersed in the fluid for a day or two. I usually check it regularly (sometimes hourly) and give it a bit of a stir. At the end you need to do some light scrubbing (usually with an old toothbrush) to get the paint out of all of the cracks and crevices.
Finally you can usually reuse the old fluid a few times. Often the paint will eventually fall to the bottom, however brake fluid is also hydroscopic (it absorbs moisture) which means that it usually loses effectiveness after awhile.
CSC is the best one however though it is hard to get in Australia.
I hope that answers your questions.
Good Grammar is Not a Time of Waste.
Old 12-03-2003, 05:12 AM
Re: stripping paint
yep, that answers them well, thanks a bunch (really helpful forums)
i just hope i don't screw up my paint job, but i most proly will as im a noob , oh well, thanks again for the help, appreciate it
(u did say csc won't pit at all right? csc is godlike no errors? and what is pit?)
Old 12-03-2003, 04:21 PM
Re: stripping paint
"pits" r pits, literally. its almost like sum1 went n took a drill or dremel n just randomly drilled shallow pits all over the plastic. also, screwin up ur paint is kinda hard. just read the FAQ, PMan is an AWESOME painter n he did a tutorial on paintin
Now Playing:
4 AWG Power/Ground
Coming Soon:
New SPL Setup
Old 12-03-2003, 06:01 PM
primera man's Avatar
"P-Man"
Re: stripping paint
How do I strip paint off a plastic model? What is "CSC"?
View All My Models Here.
Old 12-03-2003, 08:38 PM
Re: stripping paint
ahh ic, i just hope i can get a good result like that, tho mine proly wont shine...
Old 12-04-2003, 02:15 PM
Double_S Double_S is offline
I recently used brake fluid to strip a car(had to do it 3 times) and did not have any problems. I only let the brake fluid sit on the paint for about 5-10 minutes before scubbing with a toothbrush. This was the first time I ever tried brake fluid so maybe I got lucky.
Brake fluid question...stripping paint RyanGiorgio Car Modeling 3 02-05-2003 12:19 AM
Stripping paint, not with CSC auto Car Modeling 1 12-15-2002 03:21 PM
Stripping Paint NZR32 Car Modeling 9 10-22-2002 02:33 PM
best way to strip paint off of metal models smokescreen Diecast Car Modeling 5 10-05-2002 03:17 PM
stripping paint with mr.muscle?? fwdfreak Car Modeling 6 04-28-2002 05:25 AM
