Old 12-02-2003, 07:00 PM
jusername jusername is offline
Small Emissions leak 99 silverado
Hello, 1999 Z71 5.3L Extcab Shtbox 111,000miles. The check engine light is one but it seems to run fine. Autozone ran the code came up small emisions leak - recomendation was a new gas cap. So i did it and not a thing has changed. Any other thoughts? Also Today it was snowing for the first time I have owned it and the cold seemed to make it hesitate when first starting up.
Thanks
Old 12-05-2003, 01:23 AM
Poncharelo Poncharelo is offline
Re: Small Emissions leak 99 silverado
My truck also has the check engine light on. The last time it did that was about a year ago i replaced the cap and i also cleaned the evap hoses and connections on tank and evap canister, cleared codes and didnt come back for a year
Old 12-05-2003, 06:17 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Small Emissions leak 99 silverado
The PCM tests the EVAP system for leaks under certain parameters (first off the fuel level must be between 25-75%)...it looks for a loss of vacum over a period of time.
A small leak can be caused by such things as a cracked EVAP line, leaking tank seal, faulty gas cap...to properly diagnos and repair the problem you will need a scan tool and an EVAP system tester which injects a non-toxic smoke under pressure into the EVAP system to locate the leak.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
"SES light" Small emissions leak "code p0442" jbizel Grand Prix 7 07-20-2015 07:38 PM
Small water leak behind water pump geojim Metro 7 06-02-2011 07:38 PM
dakota with small emission leak code ATC mechanic Dakota 2 03-17-2009 07:37 AM
small hole leaking engine coolant Smith1978 Explorer | Explorer Sport Trac 1 05-02-2004 07:39 PM
small oil leak and slipping clutch turtlecrxsi '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-02-2004 11:19 AM
