Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 12-02-2003, 04:21 PM
90CorollaSR5 90CorollaSR5 is offline
A question for the smarties
Hey, I know this doesn't relate to street racing, but this is the forum I usually visit and I know there are many knowledgeable people in here. So, on I go.
Ok, a few days ago my car has started to hesitate while on the throttle usually only in second gear; however, just today I noticed it has started occuring much more often and in most of the gears. Its hard to explain what it feels like, I hope it doesn't have anything to do with the clutch and hope it just needs fuel injector cleaning? I don't have enough money to have trouble with my clutch... please respond. Thanks in advance.
Ignore the user name!
2007 Honda Civic Si, Taffeta White
-Injen CAI
-DC Sports Race Header
-Megan Racing Cat-back Exhaust
-TWM SS
-shifter base & cable bushings
patiently waiting for k-pro..
Old 12-02-2003, 05:09 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
could be teh injectors spark plugs wires dying check them first. HAHAHA you think i'm smart. *sets self on fire*
Old 12-02-2003, 05:15 PM
SpyderEclipseGst SpyderEclipseGst is offline
Re: A question for the smarties
Well Ive had a neon do that to me as well. But It was alot worce. My first guess would be the fuel pump. Then spark plugs, wires, injectors, bad fuel etc. But if its hesitating it sounds like some sort of fuel problem.
GT35R Tuned GSX Spyder.
Old 12-02-2003, 06:08 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Run some Injector cleaner through the tank Chemtool-12 I think is the name or something like that. If that doesn't work then it's probably the Fuel pump. I wouldn't think it is the plug wires or anything to do with the spark but might as well check all of that too.
Check out my car here My 91 Hatch
Old 12-02-2003, 06:13 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
i had a similar problem with my carburated 83 civic and it turned out that it was not spark or fuel but it was just not getting enough air so i did some playing around with the intake and its no problem. not sure it this would be the case with a fi engine tho
Old 12-02-2003, 09:34 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
change your airfliter or clean it, run the injector cleaner even tho i doubt it does anything
do you smell like a propane smell at all inside the car? check engine light on? map sensor bad?
pcv vavle might need replacing
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-02-2003, 09:41 PM
I'll try running some of that fuel injector cleaner through my tank. I doubt its the air filter, I got a new one about 20k ago. My PCV valve is pretty gummed, so that may be it. Thanks for all the advice guys.
-Injen CAI
-TWM SS
Winter tires - speed rating & downsizing Hello: A couple of questions for the forum. I have an 07 Camry LE. I am buying winter tires for her. I am jtmann Tires and Wheels 3 11-18-2010 09:07 AM
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
A question for the guroos of the XJ220 Spectre XJ220 2 10-10-2002 02:00 PM
Questions for the DETers Jay! Engine 7 08-27-2001 05:53 AM
