Old 12-02-2003, 03:58 PM
Chevychick Chevychick is offline
Angry 2002 Heat Problems
I have had 6 heater control units replaced in my S-10. They are random
Not blowing enough air
Not switching Modes
Loud High Pitch Noise when on Floor Mode and on Cold Air.
I take my truck in about every 3-4 weeks for a new blower or heater control unit!!
Does anyone have the same problem
I heard this is a common issue
Old 12-31-2003, 10:13 AM
02.ZR2 02.ZR2 is offline
Re: 2002 Heat Problems
Have the same problem with my ZR2. Replacing the actuator on the heater box will fix it for about a month. For some reason oil is getting in the actuator causing it to go bad.
Old 01-16-2004, 07:48 AM
rrankin rrankin is offline
Where is the flaper valve that controls the vent and floor settings. I have heat on defrost but I can not get it to switch over to vent or floor.
Old 02-14-2004, 08:19 PM
chevy98s10blazer chevy98s10blazer is offline
my heat doesn't blow at all..... It stays cold on my 98 zq8 blazer with computer climate control..... i don't know where to start any ideas?
Old 04-29-2004, 03:30 PM
byee's Avatar
byee byee is offline
Send a message via Yahoo to byee
Re: Re: 2002 Heat Problems
Was you able to get an answer for this question - I have the same problem with a 94 S10 Blazer.
Old 11-11-2005, 10:39 PM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
Re: Re: Re: 2002 Heat Problems
Hello, I know this is an old post but I am having the same problem but I know what the fix is. I need to replace the electronic climate control switch unit. the electronics for this is housed behind the climate control switches in the same box and the electronics has gone out. Its easy to remove and reinstall. My question is were can I find a replacment for less than 100 bucks? My truck is a 98 s10 Blazer 4x4 and the only way I will ever give it up is if it gets wrecked. thanks
Old 11-12-2005, 07:33 AM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
It's because the vacuum hose is connected to the transfer case which is then connected to the actuater and that is where the oil comes from.GM and their great ideas.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
2002 Heat Problem HC Dial Control Blend Door cahoca Galant 0 10-23-2008 10:07 PM
2002 Cavalier Heating problems juniorsbud Cavalier 3 01-10-2005 11:36 AM
2002 Heated seat problem PIGGY4 Tahoe 1 11-10-2004 04:41 PM
