Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-02-2003, 02:48 PM
blklion99 blklion99 is offline
Send a message via Yahoo to blklion99
Angry 97 rodeo problem(s)
truck was fine for about a month after purchase then i took it in to be checked out/serviced by dealer who told me everything was fine then a week later the night mare started:
alt/batt light thing (hear about this problem alot) replaced both batt and alt(reman) and it was great for about a week then alt/batt light came back so i checked voltage(it was low) replaced alt again(it lasted several days) took it back to dealer to check electrical sys for shorts and such(they say the problem is alt and tell me ALL reman alt are garbage told me to buy new from them for $386.00) replaced alt again(reman) lasted about a 2 weeks so i decided to let a real mech work on the problem went to shop that specializes in electrical repairs they say they can't find any shorts either and replace alt with one of their premium alts(they told me the whole dealer quality better than reman is hogwash spouted by dealers trying to sell parts/ i believe that because i've had a reman alt in my mitsubishi for the last 9 Years which is longer than the oem lasted/ ok back to the nightmare)that alt lasted 2.5 weeks it has since been replaced and no more batt light
now there is a new problem during deceleration tach go to 0 and truck eventually shuts off but if i hit the gas pedal quick enough the rpm's go back up and everything is good again i thought it might be the crank sensor(that runs the tach right?) but ther are no codes from the obdII scanner
can someone please help me, i have never had these type problems from a vehichle before
i bought it used so it may have been abused and i am willing to fix it but is it worth fixing or are these type problems NORMAL for a 97 rodeo with only 80k mi?
and what else will happen next?
Old 12-02-2003, 04:34 PM
surferfletch surferfletch is offline
Re: 97 rodeo problem(s)
I have a '97 3.2L V6 with 124K. I've never had those problems. I'd say 4 new alternators is not normal. Good luck.
Old 12-04-2003, 10:46 AM
rodeo02 rodeo02 is offline
You have to make sure your charging system is maintaining 14v with the truck running. If it is lower, you will get the conditions you describe. I've gone trough 3-4 "rebuilt" parts store alternators or starters with various vehilces until I got a good one. With your isuzu, if you cant get your original rebuilt by a quality shop, DEFINATELY pony up the bucks for a genuine isuzu replacement. (www.stcharlesauto.com has great prices) You see reports of this happening over and over again to those trying to use "remanufactured" alternators on thier rodeos. These trucks for whatever reason need constant, steady & clean current, and are super sensitive. IMHO- 1996-1997 (and 2001+) rodeo's are the most reliable of the rodeos, so you have a good truck!
G/luck
Joel
Old 12-04-2003, 10:20 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
I have never had a good experience with aftermarket or rebuilds I would stick with only a new one from Isuzu unless you know somone who can rebuild it for you
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
2000 Rodeo - no pwr windows, rear wiper, ac/heat, turn signals, ... ShanerX Rodeo | Passport | MU 8 09-17-2010 08:45 PM
2001 Rodeo 4wd problems Derman Rodeo | Passport | MU 2 01-20-2010 07:49 PM
93 Rodeo cranks but won't idle. Help! hansola Rodeo | Passport | MU 1 04-13-2009 08:00 PM
95 Rodeo, 1st gear will not kick in.... RedRodeo Rodeo | Passport | MU 0 04-06-2009 09:07 PM
