Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-02-2003, 10:24 AM
BobM48 BobM48 is offline
Keyless entry
Does anyone know how to detect a keyless entry system on a 1996 XLT? Is there a fuse or control box in place that one can look for, or any other way to determine if it is installed? Is the "turn on & off 5 times in 20 seconds" the only way to check it out?
Thanks
Old 12-03-2003, 04:04 PM
GIN GIN is offline
I think that is a simple enough ? to call a Ford Dealer ask them. At level worst they could tell you they don't know. Try it, what do you have to lose!
Old 12-05-2003, 01:50 PM
kekul kekul is offline
The easiest way in the explorer of that year is to switch the key from off to accessory position 5 times in less than 10 seconds. with the last turn keep the key in accessory position. if you have the keyless module installed the locks will activate (you will definitely hear it).
Old 01-24-2004, 08:54 AM
invision invision is offline
Re: Keyless entry
What do you mean by "keyless" entry?
Old 01-24-2004, 11:55 AM
XLT03 XLT03 is offline
Re: Keyless entry
invision:
Keyless entry is the remote FOB / keypad on door, factory installed to unlock doors remotely.
Old 01-24-2004, 11:53 PM
Re: Keyless entry
So, if someone had keyless entry, they SHOULD SEE it on the door then.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
